Loss of power and does not rev above 3000rpm
PajeroZam
Country: Zambia
Vehicle: Pajero 3.5L 2003
Sat Aug 24, 2019 9:30 am
Good day all.
I have a 2003 Pajero 6G74 3.5 v6. Lately it has been acting up by having some loss of power above 2000rpm and when it reaches 3000rpm it gets stuck. Foot of the accelerator back on then it pushes past.
Other times it will push past the 3000rpm on it self when you keep your foot on the Gas. I have cleaned the GDI pump, replaced the fuel filter and cleaned the mass airflow sensor, but it still does the same.
Some days it will not have the problem at all then two days later the problem will be back.
Any ideas that maybe the problem.
TIA
Jaco du Preez
Login · Register
Login  •  Register
