OBDII bluetooth/wi fi adapter to read fault codes etc on Pajero from 2007
MikeRo
Vehicle: 2007 Pajero GLX
Country: Benoni/South Africa
Re: OBD2 bluetooth/wi fi adapter to read fault codes etc
Thu Dec 17, 2015 9:58 am
MikeRo wrote:This looks amazing ..... I just placed my order :D
Ok .... so finally fitted the adapter to my Pajero and still playing with the setup :lol:
However, where can i get a comprehensive list of the codes? When i check the fault codes on the Torque app, it gives me the following:
  • P1782 [Mitsubishi] Gear 4 incorrect ratio
    P1783 [Mitsubishi] Gear 5 incorrect ratio
    U1120 [Mitsubishi] Engine (CAN message)
The CEL light does not come on, gear change is smooth and no other warning lights come on. The guys from Kaufner who fitted my chip some years back did a check prior to my fitting the adapter and according to their tool, no codes came up .... Could this possibly be 'red herring' with the app itself?
Mike
Roelf_le_Roux
Contact:
Thu Dec 17, 2015 11:21 am
Looks like you will now have to replace both engine and gearbox to satisfy the device
I sometimes wonder if there is such a thing as too much info.
Contact:
Sun Dec 20, 2015 8:02 pm
MikeRo wrote:Hi CATS
In the Aussie forum there is a reference to a 'network error' when both the the App and the engine are starting, and the solution was as follows:
When I did some reading online I discovered that it's an easy fix, you just have to change a setting in the Torque app from "automatic protocol" connect to some other one.
Did you find this setting? I cant find any obvious protocol settings in the Torque app at all?
Mike
Mike
Yes. I did find this protocol and also experienced an CEL before I set it correctly. I will find the codes and post it here as well for prosperity but currently touring so signal coverage is patchy at best so I am for all practical reasons off- grid. Will post when I am back on my bum and fully connected.
Roelf_le_Roux
Contact:
Wed Dec 23, 2015 10:52 am
Cats,
I suspect you are on yer bum and connected. Now PLEASE tell us all the secrets of the tranny temps. I know for a fact that all my ideas on what- and what-not to do with those wonderfull boxes do not include emperical data of temps.
Contact:
Wed Dec 23, 2015 5:32 pm
Still not totally back on the grid. Still haning a bit low.
Temp on the autobox was always well below dangerous levels while towing at speed. I have also adjusted to the kick down required for some hills to get it into the right gear. I did however notice 2 things:
At slow speeds going up gravel mountain passes towing, less than say30km/h, it gets hotter than it should if you leave it in high range. Rather hook Low range and it quickly cools down.
I also measured engine temps well over 100degC quite often on the app while the dash temp meter only lifts slightly to just over 50%. I suspect a big safety margin and leaneance(sp?) factor is build into the dash display.
Roelf_le_Roux
Contact:
Fri Dec 25, 2015 8:52 am
Thanks. And a blessed Xmas to you all.
Contact:
Sat Dec 26, 2015 8:17 am
Ok. To add to this post. A copy from what was posted on the Ausie forum above.
Here is what you need to do to get the transmission temp to work correctly:
Posted by glenn_cot
 Ok go to Torque home screen and click on bottom Left Hand menu, then select settings, then, select Manage extra PIDs/Sensors. Now select menu in top right hand corner, then add predefined set, then Chrysler/Dodge/Jeep/Mercedes, then Transmission Fluid Temp (GM Method 1). Now a screen will come up options for: Trans.FI.Tmp and select Edit, now edit it
change the fields first line is the heading and under it is what to change it to
OBD2 mode and PID(in HEX..... to
2102
Short name (used in Display) to
Trans Temp Pajero (orwhat ever you want to call it)
Minimum Value (typically 0) to
0.0
Maximum Value to
200.0
Scale Factor to
x1
Unit factor to
C
Equation (eg A+B+20- or [0d]+10=A or even just [0d] to
f-50
OBD Header to use (leave blank, 'Auto' or HEX header) to
TCM
Roelf_le_Roux
Contact:
Sat Dec 26, 2015 9:04 am
Cats, now I understand why they only fit a tranny temp warning light
I still think that Torque app is the best ever. Wish I had one.
Fievel
Vehicle: Pajero SWB 2008
Wed Jan 27, 2016 7:18 pm
Hi Cats. Did the config for trans temp today as above and it works brilliantly.
Contact:
Wed Jan 27, 2016 10:06 pm
Fievel wrote:Hi Cats. Did the config for trans temp today as above and it works brilliantly.
Cool. So what does the temp readings tell you? I find that the transmission is usually about 20degC lower than the engine coolant temp, except when really worked hard then they creep closer to each other.
Also. My car feel somewhat flat("pap"), to me anyway, so I am trying to determine if it is boosting as it should on the turbo. Please keep some tabs on your boosting readings for a while - please. I would like to exchange notes at some stage on this.
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
Login · Register
Latest Posts
Login  •  Register
