Weird uneven idle on my Gen 4
Mitsu Fan
Country: South Africa
Vehicle: Pajero Gen 4 2015
Mon Feb 11, 2019 11:04 am
Hi guys.
My 2015 Gen 4 with 75 000 km on has developed a weird idle problem.
When I stop dead at a stop intersection or traffic light the engine idles with a lumpy feeling for about 3 seconds and then goes away. Problem is that this is very infrequent and mostly random.
Some guys point to dirty transmission fluid but the oil change only comes at 100 000 km.
I have done some tests as suggested by selecting neutral just before I stop to see if it persists. But being so infrequent it is difficult to select neutral when it happens because the period is so short.
Any ideas ?
Sent from my SM-G960U1 using Tapatalk
The Mul
Vehicle: 2007 LWB Pajero DiD
Re: Weird uneven idle on my Gen 4
Tue Feb 12, 2019 11:25 am
I though Transmission Fluid interval was every 60 000km?
Mine has started with the same occasional slight variation in idle speed, I suspect the SCV (suction Control Valve) from what I have read. Min is due for 260k service in 500km, so I will be doing that first (incl new air/diesel filters) and then decide if further action is required
Henk
Contact:
Wed Feb 13, 2019 10:33 pm
Maybe top up the diesel tank with some fresh juice as a start. Also make sure the airfilter is nice and clean.
Can't hurt to start with the small things.
RoelfleRoux
Country: SA
Vehicle: 2008 3.8V6 LWB Pajero
Thu Feb 14, 2019 9:39 am
I think your Pajero needs some fresh Barberton mountain air. I can assist with that!!
PS. All Pajeros run better on fBma
Mitsu Fan
Sat Feb 16, 2019 9:23 pm
Thanks guys.
@Henk I queried this with the dealership after the 60 000km service and apparently the 2014 onwards have a high output transmission which only requires changing at 100 000km. The service book confirms this.
@CATS I will start going through those basic items and see what pops up.
@Roelf I cant agree more. We need to set up that weekend we spoke about last year to go play in the mountains seeing I cannot come in the week to discuss mining machines with your Engineer. Pity......
Henri
Who is online
Login · Register
Latest Posts
Login  •  Register
