Auto box, T-case and diff ratios
Forest Fab
Vehicle: 1997 Pajero LWB [sold]
Country: South Africa
Wed May 17, 2017 10:25 am
Hi guys,
I'm struggling to find any clear information on the auto box, transfer case and diff ratios found in the Pajeros.
Other questions besides the actual numbers:
- auto box: are the ratios the same between a Gen2/2.5 3.5 V6 petrol (although 4 speed box, so no...), a Gen 3 3.5 or 3.8 V6 petrol and a Gen 3 3.2 DiD (5 speed)?
- transfer case: I had read at some point that there was a front/rear gear reduction because the diff ratios were different. Is this true?
If someone can shed some lights on what ratios were fitted to what engine, that would be great!
Thank you in advance.
I am not stuck, I am just momentarily unable to move...
Return to “Drivetrain”
Who is online
Login · Register
Login  •  Register
