Troubleshooting 4x4 Super select lights
lunnmj
Country: South Africa
Vehicle: Pajero 3.2 DID SWB
Re: Troubleshooting 4x4 Super select lights
Mon Apr 20, 2015 5:37 pm
hogbeast wrote:Many posts do not mention that the actual sensor on the gear box can also cause the flashing lights. My centre diff sensor was dirty. Clean it nd problem solved
Thanks Hogbeast
Where exactly does this sensor sit ?
hogbeast
Country: south afica
Vehicle: pajero gen2 1996
Mon Nov 30, 2015 9:07 am
sorry that i did not see the question.
did you manage to fix the problem?
super select pic.docx
thanks to 4ePikanini
(89.31 KiB) Downloaded 110 times
1996 Pajero 2.8 TDI LWB
lunnmj
Mon Nov 30, 2015 5:39 pm
Thanks for asking.
I do not know as I checked all the vacume pipes and the actuator works. I unplugged the plug on the transfer lever, sprayed contact cleaner there then cleaned the vacume valves under the airbox and swopped them around. Lights remain normal so far. I will only probably see on a long trip.
hogbeast
Wed Dec 02, 2015 8:53 am
ok. lets hope it is fixed. those intermittent faults can leave one frustrated.
how i released it must be the sensor/ switch, when i pull the 4X4 gear shift back the light went out
Return to “Drivetrain”
Who is online
Login · Register
Login  •  Register
