Squeaky rear door seal
saltydog
Fri Feb 09, 2018 4:53 pm
I've not posted for a long time and hope this has not been answered before!
I have a 2008 3.2D shorty.
Developed an irritating squeak on the rear door (even on tar ).
Is it time for a new seal or is it an adjustment the dealer should make?
Many thanks.
KurtG
Country: South Africa
Re: Squeaky rear door seal
Sun Feb 11, 2018 8:21 am
Hello saltydog.
Although it could be the seal due to age, try adjust this latch about 2mm “inwards”. Simply loosen those two funny screws enough to allow the latch to move by tapping with a hammer lightly. The latch only needs about 2mm forward movement to allow the door to close a little tighter.
If you move it too much then the door will be very difficult to close and open. Give it a try and see if that helps.
saltydog
Sun Feb 11, 2018 4:00 pm
The seal looks reasonable. So I'll give it a try.
Many thanks
moldie
Vehicle: Mitsubishi Pajero LWB GLX Gen 4
Mon Feb 19, 2018 8:57 am
Hello saltydog.
Give that man a bells. You sir have helped save my sanity.
KurtG
Mon Feb 19, 2018 10:50 am
moldie wrote:
Hello saltydog.
Ha ha ha ha, that’s brilliant. Glad I could help
Jacovv
Vehicle: 2005 Pajero GLS DiD
Wed Feb 21, 2018 10:32 am
As alles klaar op hulle maksimum gestel en geskuif is, soos myne, en nog steeds squeak - ek het 'n bree cable tie om die rubberblokkie, wat aan die deur vas is, gesit. Doodstil daarna en baie grondpat intussen gery.
Jacovv
Wed Feb 21, 2018 10:33 am
As alles klaar op hulle maksimum gestel en geskuif is, soos myne, en nog steeds squeak - ek het 'n bree cable tie om die rubberblokkie, wat aan die deur vas is, gesit. Doodstil daarna en baie grondpad intussen gery.
Curly
Vehicle: 2015 Mitsubishi Pajero SWB 3.2 DiD GLS
Thu Feb 22, 2018 11:19 am
I also experienced the squeaky rear door and after trying everything, I found that the squeaking is actually cause by the the little round rubbers on the door.
I stuck felt floor protectors (for furniture legs) opposite each rubber and.....no more squeaks......
Observe the small white circles on the door and frame.......
The attachment Rear Door Squeak 2.JPG is no longer available
The attachment Rear Door Squeak 3.JPG is no longer available
Hope it works for you!
Glyn
2015 3.2 DiD GLS SWB - Acquired Oct 2015 currently on 40,000kms
2002 3.2 DiD GLS SWB - Acquired Jan 2013 on 297,000kms (sold Dec 2016)
Curly
Thu Feb 22, 2018 11:23 am
Curly
Thu Feb 22, 2018 11:24 am
Who is online
Users browsing this forum: No registered users and 2 guests
Login · Register
Login  •  Register
