Where is the washer bottle?!
johne999
Country: Kenya
Vehicle: Pajero
Fri Apr 13, 2018 9:01 am
Can anyone help, I have a 2004 Pajero LWB RHD in Kenya, the front washer bottle started leaking, I cannot see where it is, or what to remove to get to it. It seems I have to remove the entire front bumber, as there is no sign under the headlight nor if I remove the mud shield under the RH arch.
Any guidance, links, pics, etc will be helpful.
John
Contact:
Re: Where is the washer bottle?!
Sun Apr 15, 2018 9:00 am
It is inside the fender and behind the bumper. Quite a large complicated design. Maybe search for snorkel fitment instructions on that Pajero model as I know some designs require removal of old washer bottle and instalation of new one to make space for snorkel, so you might get some ideas there.
h_hezzah
Country: Egypt
Vehicle: Pajero NM 2001 3.5 Aut LWB
Sun Apr 22, 2018 11:04 pm
From behind the fender you can reach the pump to check if it's seal is leaking, then you can replace it from there.
If the bottle itself is leaking then you unfortunately have to remove the front bumper to be able to remove it.
Who is online
Login · Register
Login  •  Register
