Starter motor 3.2 DiD
Mi
Mike Terra
Sun Aug 26, 2018 6:38 am
Does anyone know the part number for a 2006 Pajero with a 4M41 engine? (3.2 DiD diesel engine.) Any recommended suppliers outside of the Dealer network.
Graemem
Vehicle: 2001 Pajero 3.2 LWB
Re: Starter motor 3.2 DiD
Sun Aug 26, 2018 11:27 am
Hi Mike
The 3.2 Starter is a bit of a nightmare. What is wrong with your starter?
Normally it is only the brushes and occasionally the solenoid. It is a simple fix.
Tunja
Vehicle: Pajero 3.2 SWB '2000
Mon Aug 27, 2018 12:36 pm
Hi Mike, I managed to get hold of a aftermarket starter here in Ct. Will pop past the electrician that got it for me and get some contact details for you. think was R2500-3000
Afdak
Vehicle: 2012 Pajero 3.2 DiD Legend auto
Sun Sep 02, 2018 5:21 pm
Hello GraemeM,
I have an automatic Gen 4 3.2 DiD and have worries about being stuck in the bush with a failed starter.
Why do you say this starter is a nightmare:
- is it difficult to remove in the field?
- should I carry spare brushes
-can the brushes be changed in the field or is some heavy soldering required?
-part number for the brushes?
- are there warning signs of impending starter failure?
@ Tunja - did you get the contact for the aftermarket starter supplier?
Pajero 3.2D Legend auto 2012
- EFS coils
- Airbags in rear coils
- Full bash plates and rocksliders
Kia Sportage 2.0D auto 2014
Invader Duo Offroad trailer
joe bergh
Vehicle: Pajero swb 3.2 did
Mon Sep 03, 2018 7:55 am
My 2003 swb DID is going in for a starter tomorrow in Hermanus....it started to sound as if battery is faulty...will revert when I get a quote from auto elec. Joe. :roll:
dwinter
Vehicle: Pajero SWB 3.2DiD
Tue Sep 04, 2018 2:01 pm
I had to refurb my starter twice in the 5 years that I owned my 2004 DiD SWB.
Both times the symptoms were a slightly slower / longer crank time on starting that seemed like the battery was going flat. On both occasions, an auto elec just opened it up, cleaned it out and installed a new brush kit. I can't recall exactly, but think it cost me between R1.5 - 2k each time.
I believe these starters get gunked up because they sit under the fuel filter and when your mechanic removes the filter some of the diesel spills onto the starter, which over time causes issues. Solution - put a plastic packet over your fuel filter when removing it, or remove the entire filter bracket from the car when removing it.
Here's a thread I started on this topic a while back:
https://www.pajeroclub.co.za/forum/view ... =24&t=4845
Cheers,
Dave
Pajero 3.2 DID LWB GLX
Pajero 3.2 DiD SWB [SOLD]
joe bergh
Wed Sep 05, 2018 7:32 am
The auto elec cleaned starter and refitted. Starts like a new car now....R800 later. ;) Yes it does sound like a battery going faulty. Joe,
Tunja
Thu Sep 06, 2018 1:17 pm
Hello GraemeM,
Sorry for the delay i been away.
This is the guy that sourced my starter in CT
Lewyllen
L.A. Willards Auto Electrical Repairs cc
5,01 Google review
Auto electrical service in Cape Town, South Africa
Address: 12 Boundary Rd, Strand, Cape Town, 7140
Phone: 021 854 4454
Graemem
Fri Sep 07, 2018 9:19 pm
Hi Guys
Sorry for the delayed response.
These starters get diesel on them from filter changes. The brushes and the solenoid give problems because of this. Both of these are easy to fix and replace. The starter can be removed in 10 minutes even in the bush. Fitting new brushes or the solenoid can be done in about 20 minutes.
I replaced my solenoid and brushes, the parts cost me R300 labour involved two coffees made by me.
I hope this helps.
PS the starter is so much easier to take out from the bottom....
Login · Register
