Brake shudder
stevedcp
Vehicle: pajero 3.2 swb 2009
Country: south Africa
Brake shudder
Tue Aug 15, 2017 1:40 pm
Hi all, have a problem on my 2009 swb, have fitted power brakes all round, but still have brake shudder at higher speeds, anyone else got this issue?
Sent from my ALE-L21 using Tapatalk
JTEC
Vehicle: 05 Pajero 3.2 DiD LWB
Country: South Africa
Re: Brake shudder
Wed Aug 16, 2017 7:42 am
stevedcp wrote:Hi all, have a problem on my 2009 swb, have fitted power brakes all round, but still have brake shudder at higher speeds, anyone else got this issue?
Hi Stevecp
Did you fit new disks and pads?
Im not 100% sure about this but I have read that the caliper bolts sometimes rust and and dont allow for the caliper to self position properly causing the pads to rub against the disk.
Maybe the pros can correct me or provide more info?
JTEC
Greg_SA
Vehicle: 2008 Pajero DiDc LWB
Re: Brake shudder
Thu Aug 17, 2017 10:53 am
Did you fit the parts yourself, or someone else?
Disks and pads?
Powerbrake supply detailed instructions for fitment and initial bedding in of the brakes.
It is very important to clean the hubs very well. I used steel brushes, steel wool, etc to clean mine.
2008 Pajero DiDc LWB GLS
stevedcp
Re: Brake shudder
Fri Sep 01, 2017 10:05 am
New discs and pads fitted myself, cleaned hubs, and followed all instructions, thinking it may be suspension bushes.
Sent from my VFD 1100 using Tapatalk
peterpot
Vehicle: 2009 Pajero 3.2 SWB
Country: SA
Re: Brake shudder
Fri Sep 01, 2017 5:50 pm
Some time back I posted on another forum my experience with brake shudder on a Gen3. I bought it and inherited a brake shudder. The owner had had the discs skimmed and when on his behalf I returned to the agents they simply wanted to skim again. I was not happy and told them so. I went home and on investigation i found that the rear calipers have special bolts which allow the caliper to move as the pad wears. Although there is a rubber to keep rubbish out, these bolts had rusted / seized inside the calipers. I had to drill the caliper from the opposite end with a small drill bit and squirted release oil in over a few days until I could loosen them without breaking them. Once loosen off, I sealed the drilled hole with silicone and lubricated the non threaded section with grease. The shudder was gone!
stevedcp
Re: Brake shudder
Fri Sep 01, 2017 8:57 pm
Will check them, thanks.
swazi85
Vehicle: 2011 Pajero Gen 4 3.2
Re: Brake shudder
Sun Nov 12, 2017 6:01 pm
Sorry can I enquire what the powerbrakes cost you?
Sent from my SM-N950F using Tapatalk
stevedcp
Re: Brake shudder
Sun Nov 12, 2017 9:14 pm
Its about R8.5k all in.
Return to “Suspension, Steering and Brakes”
Who is online
Login · Register
Latest Posts
Login  •  Register
