Steering vibration
Andrew.dua
Vehicle: Pajero LWB Exceed
Steering vibration
Sat Apr 23, 2016 2:28 pm
I have a 2015 Pajero Exceed with 17" tyres. From the beginning I can't seem to get rid of the vibration between 120-140, they replaced the Dunlop tyres with Yokohama but it didn't make much of a difference. I have done wheel balancing numerous times, any suggestions? Different tyre brand? Anyone else with a similar issue?
Theodorus
Vehicle: 2004 Pajero
Re: Steering vibration
Sun Apr 24, 2016 4:43 pm
i had my wheels ballanced by qiuck fit then i had the sam problem i then wnet to wheel and tiger and they re did it and its now all good
does a mag place not check the rims maybe there is a problem there just a thought
Jabulani
Vehicle: Mitsubishi Pajero
Mon Apr 25, 2016 10:49 pm
I had a similar problem with my Gen4 Pajero Exceed. I went to TWT in the Vaal, it didn't go and when I arrived in Nelspruit I went to TWT in the town and they fixed the problem at once.
mulderpm
Vehicle: Pajero DID 3.2 Diesel 2005
Wed Dec 04, 2019 1:12 pm
I had the same problem. After doing balancing, rotation and even replacing one of the tyres the problem persisted. In the end the cause was a warped brake disk. Mitsubishi skimmed all the disks and the problem was solved. I Just wonder how the disk got warped?
PS: The problem tyre/wheel was also running 10 deg hotter than all the others. The hub was so hot you could not touch it!!
Return to “Rims and Tyres”
Login · Register
Login  •  Register
