Rock Sliders for a Pajero Generation3 CK LWB
Contact:
Tue Oct 19, 2010 6:38 pm
Rock Sliders as defined by Wikipedia ( http://en.wikipedia.org/wiki/Rock_sliders :
Rock sliders are an aftermarket accessory popular among four wheel drive vehicle owners who engage in more serious off-road driving.
Rock sliders are typically made of heavy-duty box section steel, although they can also be made from tubular steel as well. They run along each side of the vehicle, from just behind the front wheel to just before the rear wheel, just below the level of the door sills. They are affixed to the vehicle's chassis, and their function is to protect the door sills and door bottoms from damage when crossing large obstacles (such as rocks - hence the name).
This is what I went to find when looking to add some mods to my Generation 3 LWB Pajero. I found some good ones at Burnco and Lynx4x4 but in the end decided on Org from Tough Stuff as he has built a number of these things for Cruisers and Prados and specialise in Rock sliders and not any other 4x4 accesories. Furthermore he came highly praised in this post viewtopic.php?t=339 Who said a Gen3 does not have a chassis rail and can't fit sliders!! 8-)
My LWB (2001) model would have been the first LWB Pajero that he made, so it took about a week to get it done. The 2000-2004 LWB (only GLS models were available then) Pajero have a different bottom 'tupperware' design than later models which I wanted modified and cut to prevent further damage, especially to the front mud flap part that looked battered and bruised on my vehicle. Org convinced me not to go too extreme in the end with the cutting of the plastics and this what we ended with in the end.
This is what it looked like before the slides were fitted.
What I like:
They are narrow enough to not be in the way when entering the vehicle but still wide enough to assist the kids in getting in and out.
They blend in nicely with the car without attracting too much attention. I opted for silver paint rather than the standard black powder coating.
They give superior protection and are probably overengineered with an extra bar under the 'pinch' line on the vehicle to assist in carrying the weight if they do move when used for lifting.
There is extra gusseting used on the standard monting points to spread the load when used.
The Hi-Lift points are a geart bonus for emergencies in extreme situations.
What I dont like:
They are heavy weighing in at almost 60kg for both sides according to Org due to the exctra thick steel used. The price for durability.
They took a small amount of clearance away on the side of the vehicle, althogh they are equal to the lowest point on the vehicle being the exhaust.
Price was just under R5000 with 50% deposit upfront.
JP
JP1
Re: Rock Sliders for a Pajero Generation3 CK LWB
Wed Oct 20, 2010 5:13 pm
Cats, hulle is seker swaar, maar hulle blend nogals mooi in by die standaard lyne vd Pajero. Lyk nice.
Contact:
Mon Apr 11, 2011 7:37 pm
Here are some more pictures as requested by a member
jotto
Contact:
Vehicle: Pajero SWB 3200 Di D 2001
Thu May 05, 2011 8:13 pm
Looks fantastic, profesional looking.
Di-D 3200 SWB 2001
nino62
Vehicle: 1) Nissan Patrol 3.0Di GL S/W 2001
Thu May 05, 2011 8:45 pm
Hi Cats
The rocksliders look really strong and functional, also pleasing to the eye. 8-)
Is that still the plastic original bash plate is see in your earlier photos of last year??
Achille
2) Nissan Patrol 3.0Di GL 2001, TJM Gold Ed. susp., BFG AT's on D. Cepek rims, TJM snorkel, LED's, drawer syst, 40lt Engel, FR roof rack, XT120 Jurgens trailer + HM RTT + room & HM awn, NL aux batt. & solar
Contact:
Thu May 05, 2011 9:15 pm
nino62 wrote:Hi Cats
Achille
Achille
Not sure if I understand correctly, the only plastic bashplate I see in my photos are the plastic plate fitted underneath the fuel tank? If this is the item that your refer to then yes, it is still the original. Not worth much as I dented the diesel tank some years ago and now look after it more carefully(They cost a bundle to replace). There is not a tank steel bashplate readily available in South Africa, but ASFIR(Israel based manufacturer) make some great ones that I found on the internet.
Why do you ask?
nino62
Thu May 05, 2011 9:27 pm
Hi Cats
Think I got the bull-by-the-tail then :oops: Thought it looked like the original engine lower cover plate......which are way too thin for serious off-loading. Hence assumed that as you fitted a "dinkum" rock slider setup, you might have also considered the bottom bash plate upgrade ?
Achille
DandB
Country: RSA
Vehicle: Pajero 3.2D
Sun Jul 24, 2016 12:07 pm
Please post some pics of the long range tank before it gets installed - I've spent a long time looking at options and don't see anything too promising, but I', willing to be convinced.
Good luck.
Contact:
Sun Jul 24, 2016 7:21 pm
DandB
You revived a very old thread and refer to a long range tank, which was not even in the topic? So not sure how to respond except by saying that I have long since sold that vehicle.
zeek
Contact:
Vehicle: Pajero 3.2 DiD GLS AT 2002
Mon Jul 25, 2016 11:16 am
DandB wrote:Hi,
Good luck.
You are in luck I just had my long range tank removed and would liek to sell it.
Will post some pictures tomorrow
Riku
Echo 4 2011
Login · Register
Login  •  Register
