Colt 2.8 TDI cold start issues
If you drive a Mitsu but it's not a Pajero, this is the place to chat about your vehicle.
Bernard
Vehicle: Gen 3 Pajero 3.2 LWB
Country: South Africa
Tue May 03, 2016 10:28 am
Hi Guys
I need help please !! A friend has a colt 2.8 TDI that has cold start issues. It struggles to start and then cuts out, spluttering and smoked like crazy. We have replaced the glow plugs which were damaged.
Please see the attached pictures. Yesterday, I saw clean diesel coming out of the top of the pump.
Any advise would be appreciated.
4ePikanini
Contact:
Vehicle: 2001 Pajero LWB 3.2 Di-D GLS
Re: Colt 2.8 TDI cold start issues
Tue May 03, 2016 11:17 am
it is the diesel pump input shaft seal.
If it can let air in, it can let diesel into the sump. A 12v pump is a redneck fix. It can cost you your life if you have a runaway engine from diesel dilution in the engine oil.
Take the pump off, have the seal replaced. Make sure they put the seal slightly offset to where the old one was running.
PS : regular oil changes and the use of 2SO greatly extends the life of that seal, but it can NOT fix it once it leaks.
Marius Fourie
MY DIY WEBSITE
2005 Touareg R5 Air & Bi-Xenon
Return to “Other Mitsubishi 4x4 / AWD”
Who is online
Login  •  Register
