Rear Diff Noice
If you drive a Mitsu but it's not a Pajero, this is the place to chat about your vehicle.
francoissteyn
Country: South Africa
Vehicle: 3.2 did
Rear Diff Noice
Mon Jul 16, 2018 10:01 am
Hi All
I have a singing (hummmm) noice on the rear diff that seems to be louder on lower speed. It seem to be fine and does ingage in 4wd etc. Is this fixable or should I replace.
Hugen0408
Vehicle: Pajero 1998 3.5 petrol
Re: Rear Diff Noice
Mon Jul 16, 2018 3:22 pm
Hi.
When last did your vehicle enjoy a full lube service?
Years ago I had this humming sound on my Ford bakkie 3.0L V6 diff.
The outcome, the diff was very low on oil. This causes the diff to run quite hot.
After filling the diff with oil, the humming sound was gone.
This might not be in your case.
However, do check if there is any oil deposits around the diff nut/screw. If so, that explains a whole lot.
Honestly hope you come right.
francoissteyn
Vehicle: 3.2 did
Re: Rear Diff Noice
Fri Jul 20, 2018 10:45 am
Thanks for the advise. it seems there is some oil around the housing. Will check where the origin is and hopefully you are right. Topping it up might solve the prolem.
peterpot
Country: SA
Vehicle: 2009 Pajero 3.2 SWB
Re: Rear Diff Noice
Sat Jul 21, 2018 3:44 pm
Do you have a Gen 3 or Gen4 diff lock or not ?
Return to “Other Mitsubishi 4x4 / AWD”
Who is online
Login  •  Register
