Shocks needed
If you drive a Mitsu but it's not a Pajero, this is the place to chat about your vehicle.
Lienkie
Vehicle: Mitsubishi Pajero 2005 DiD GLS
Shocks needed
Fri Aug 25, 2017 8:45 am
Hi there, please assist with some advice - I drive a 2005 short wheel base pajero - she is in need of new shocks and need some advice as to what make I should buy - please keep in mind that I do not do offroading with her - do sometimes drive gravel roads but nothing extreme - also advice on what tires to fit would be welcome!
Thank you in advance. :)
Hugen0408
Vehicle: Pajero 1998 3.5 petrol
Re: Shocks needed
Fri Aug 25, 2017 11:36 am
Hi Linkie.
I am not to clued up as some of the members that runs Pajero Gen 1 to current.
I have a Pajero LWB Monday past i fitted front and rear shocks at Tonnesen/Best Drive (Diep Rivier in Southern Suburbs C.T. ) at a cost of R4162. The brand fitted was Monroe.
My previous brand was Bilstein.
Remember if you search shock absorbers on the forum you will find a lot of valuable info which brand is best suitable for your make vehicle.
I also searched my shock defect on the forum.
Hope this is of some help to you.
Best Regards.
Hugen
Lienkie
Re: Shocks needed
Fri Aug 25, 2017 11:59 am
Thank you so much for the advice Hugen - will definitely look into searching the forum for shock advice - I was told that Monroe is a good quality.
Have a good weekend.
Lienkie
Return to “Other Mitsubishi 4x4 / AWD”
Login  •  Register
