Update time again, Made it out to the farm to start smashing out the interior, and good progress was made, basically ready to come back and just weld it up. shes slowly getting there. hopefully next break the body work is done. Im clearly horrible at quoting this type of work.. haha.
back wall:
coverings in place:
Window frame in place, still needs grinding and a good clean up. but minimal warpage.
Thats enough for now. Im out for another 2 weeks. so I shall continue then.
Pajero Mk1 Tourer build-up
- cruisn06
- Vehicle: 1990 Mitsu Pajero LWB
Post
Re: Pajero Mk1 Tourer build-up
07 Mitsubishi Pajero Shorty - The bush basher
90 Mitsubishi Pajero Ute - the project
89 Mitsubishi Pajero Shorty - The rolling resto
89 Mitsubishi Pajero Exceed - The donor
- cruisn06
Post
Shes done and headed for paint. the mechanical will go quickly. happy with how it looks multiple different colours so one solid colour should look mint.
- cruisn06
Post
- cruisn06
Post
- cruisn06
Post
Since shes at the paint shop I had time to fab up some steel racks and clean up the container. then with a new empty area I rolled in the donor and began stripping the trans and a few other goodies I want for the ol girl.
My thinkin area:
My thinkin area:
- Marty Russell
- Country: RSA
- Vehicle: 1986 Mark 1 Pajero 2.5L Turbo Diesel Wagon
Post
I suggest that you be wary about how much is skimmed off the head and only do it if it is absolutely necessary. The pistons at TDC are level with the top of the cylinder block, so the clearance between the piston and the head at TDC is only the thickness of the head gasket.
Since 1999 I have owned two Mk1 Pajeros identical to yours. My wife and I have travelled in a Mark 1 all over the southern half of Africa including a trip to Nairobi and back and we recently tackled some of the Eastern Cape passes including the Bastervoetpad Pass.
You have done yourself a big favour. No electronics - apart from the glow plug timer, which usually has to be replaced with a push button on the dash and most mechanical spares are available at reasonable cost from Midas because the early Colts are identical.
One word of advice - do not use Goodyear RAM fan belts. Use only Mitsubishi belts. Please contact me if you want more info.
1986 Mark 1 Pajero 2.5L turbo diesel station wagon
1993 220si Toyota Camry saloon auto
- cruisn06
Post
Part way through paint and looking amazing. very happy with how factory it looks. still has black pin stripes to come. All that effort in metal forming clearly paid off.
- cruisn06
Post
- 4ePajero
- Vehicle: 1989 Pajero LWB
Post
That is looking fantastic!
(It brings back memories of my Gen1 build!)
Check your PMs
Check your PMs
- cruisn06
Post
Thanks mate.
Havent recieved any messages either.
4ePajero wrote:That is looking fantastic!
Check your PMs
Thanks mate.
