07 SWB touring build
Show off your ride!
cruisn06
Vehicle: 1990 Mitsu Pajero LWB
Tue Jan 08, 2019 2:46 pm
It never ends, figured I'd post up some more pajero love. my other project is still on the go but I needed to get out in the mean time, so I picked up an 07 shorty. Ill do a from start build up over the coming weeks. as the build is almost already complete.
Mods: Sahara bar, custom rear dual carrier, Aux tank, sliders, under body armour, airbags, 50mm lift, winch, uhf, touch screen stereo, drawers, dual batter, pre fuel filter, snorkel, chip tune, dpf delete, 3" exhaust, auto lock up kit, pedal box, roof rack, awning, roof top tent.
Good little wagon, Here is how it sits now:
How it came:
07 Mitsubishi Pajero Shorty - The bush basher
90 Mitsubishi Pajero Ute - the project
89 Mitsubishi Pajero Shorty - The rolling resto
89 Mitsubishi Pajero Exceed - The donor
cruisn06
Re: 07 SWB touring build
Tue Jan 08, 2019 2:47 pm
Continuing on with the build, due to adding dual spares the rear door looked terrible. so I have to fix that
Looks terrible, holes, and pressings:
Chop chop time:
cruisn06
Tue Jan 08, 2019 2:50 pm
Due to added weight I have had to upgrade my rear springs. basically I set the wagon up as a weekend warrior so it was never meant to hold this weight. So I got a set of efs 50mm lift 500kg constant springs to install
Also with the chip I have had my bypass open a few times so got a blocker:
And finally, a little more fuel storage:
Contact:
Wed Jan 09, 2019 7:23 am
Looking good and properly set up for your intended use.
Thanks for sharing.
RoelfleRoux
Country: SA
Vehicle: 2008 3.8V6 LWB Pajero
Wed Jan 09, 2019 1:04 pm
Wow!
What a neat setup.
Thanks for sharing.
Jannie de Wet
Country: RSA
Vehicle: Pajero SWB
Sun Jan 13, 2019 9:22 am
Wow! That looks nice.
cruisn06
Thu Jan 17, 2019 2:55 pm
Well the pressure is on to finish the rig. its got an adventure planned.
I started with upgrading the rear suspension.
I got some EFS coils which were a bust as per photo:
So I went by to my tried and true Dobinsons, these are 250kg constant load for a lwb or a fully prepped shorty.
Thats heaps better:
Engine is getting some work done, new alternator, resealing the intake and making a new egr block, I also have a catch can and water seperator to install still.
And the wiring never ends, hooking up the LED light bar, the winch is getting hard wired into a switch for easier use, and I have hooked up the dual battery system link kit. more photos when its all cleaned up
[URL=http://s85.photobucket.com/user/cruisn/ ... u.jpg.html][IMG]http://i85.photobucket.com/albums/k48/c ... 2ogngu.jpg[/
KurtG
Country: South Africa
Thu Jan 17, 2019 8:47 pm
Good work sir
cruisn06
Sun Jan 20, 2019 3:38 pm
The work continues. suspension is in and looking great, along with the jerry can holder.
I can now carry about 160L which covers me for 1000kms regardless of terrain. or 1500 of highway at 95-100ish.
Also the electrical, new stereo installed, the ebay unit was killing the battery so now I have cleaned all that <censored> wiring up and installed a kenwood deck.
Before:
After:
And some poser shots:
cruisn06
Wed Jan 30, 2019 2:41 pm
Continuing on with the build... more and more electrical. at least its all done now. basically the winch is now on a switch, battery controller switch is in the cab to. I have also wired in usb charging ports and a setup to charge my drone batteries. along with a new stereo.
Inside the tent got lights and 2 usb charging ports.
Exit point for all power:
Fridge redone in heavier cable:
Engine got its secondary fuel filter reinstalled, and a catch can, along with a full service.
And I found a spacecase for storage in the back for clothing and also acts as a barrier.
Who is online
Users browsing this forum: No registered users and 2 guests
Login · Register
Login  •  Register
