Pajero 3.2 DiD struggles to start
This is where general information is stored for reference purposes. Please do not ask questions here. Only post here if you are posting reference information.
ha
hanslam
Sun Dec 19, 2010 12:59 pm
My 2005 Pajero 3.2DiD GLX with 210 000 km on the clock suddenly struggles to start. First of all I did a battery test but the battery was fine. I took it to an auto elect. to test the glow plugs and electrical system, this was also fine. He then said that it could be either over fuelling caused by a leaking injector or under fuelling caused by a worn diesel pump rotary. When the engine is cold, it cranks for about 4-5 sec then starts (without a jump start), if the engine is warm it takes about 6-10 sec before starting (with a jump start).
Is there anyone with an idea of what causes this problem and what would the next step be in solving this? Of cause as efficient and economical as possible.
4ePikanini
Contact:
Re: Pajero 3.2 DiD struggles to start
Sun Dec 19, 2010 7:23 pm
When you have been driving a while and shut it down, will it start back up immediately? Or is you starting problem only on cold start?
If its only cold starting you may have a leaking diesel hose or leaking diesel filter gasket.
ha
hanslam
Sun Dec 19, 2010 8:46 pm
The problem is not only on cold start but actualy worser when starting hot.
tonton
Country: RSA
Vehicle: 2007 3.8 GLS LWB (Gen 4)
Mon Dec 20, 2010 12:11 am
hanslam wrote:The problem is not only on cold start but actualy worser when starting hot.
I once had a similar problem on a 'platkar', and the problem turned out to be a faulty diode on the alternator.
Just a shot in the dark, but do check it out...
Pajero 3.8 GLS (A) LWB 2007 (Gen 4)
Pajero 3.5 GLS (M) LWB 2000 (Gen 2.5) SOLD
Pajero 3.5 GLS (A) LWB 1995 (Gen 2) SOLD
4ePikanini
Contact:
Mon Dec 20, 2010 6:12 am
maybe a simple fix. check that the temp sensor in the head's connector is still attached.
if you are mechanically able you can try the following
wire in a status light to the glowplug feed to see when the glowplugs are actuated.
remove the injector rail and crank to see if diesel is being sprayed from the get go
have a compression test done - are you down on power or using oil?
Try a friend's fairly new battery
try to clean the battery terminals and ground connections.
Country: SA
Mon Dec 20, 2010 9:23 am
hanslam,
Do you run on 50 or 500ppm diesel? I found my DiDs cranked a bit longer with the 50ppm diesel.
I agree with the notion of first trying a new battery.
Roelf
ha
hanslam
Mon Dec 20, 2010 4:57 pm
Thanks for the advice so far, will check it out. I run on 500ppm diesel.
Fr
FrikkievN
Tue Dec 28, 2010 9:08 am
Ek het die selfde probleem gehaat. Kyk na jou positiewe battery clamp jy sal sian dat die clamp bout om die battery pool van en dan agter toe bout jou positiewe draad wees vas aan die clamp. Maak die draad daar los dink dus n 13 spanner en maak die kontak punte skoon. Ek was ook verbaas toe ek sien dit was die fout.
Hoop dit help jou !
Mens moet altyd eers na die klein goedjies kyk voor mens groot gaan ! :mrgreen:
ha
hanslam
Thu Jan 06, 2011 10:15 pm
Hi Fellas,
Sorry for taking so long to give you the answer! The starter motor was the gulprit. I replaced it for R2800 from Bosch and si daar alles weer reg.
Hanslam
lesc
Vehicle: Pajero 3.2 DID
Wed Dec 19, 2018 10:52 am
My Pajero 3.2 DID 2004 Also recently started giving starting problems.
I have replaced the battery as well as the Glow plugs at a price.
The local Mechanic recommended the I replace the Glow plugs and the problem should be resolved.
He now says He needs to check to whole fuel line and it should stop the problem. The Cost = - R8000.00
I am requesting advice as I get the feeling our Local Mechanic is trying to rip me off.
Login · Register
Login  •  Register
