Whatsapp Group
fungface
Country: UGANDA
Vehicle: Pajero io 1999
Re: Whatsapp Group
Wed Oct 17, 2018 3:42 pm
my number is +256794705901
please add me on the whatsup group
Thanks.
EugeneGen2
Country: South Africa
Vehicle: Pajero 2.8 gen2
Re: Whatsapp Group
Sun Oct 21, 2018 8:14 am
Hey Please add me to the group 083 2777 354. Thanks
GROBBIE
Vehicle: 2009 Pajero 3.2 5 door GLS
Re: Whatsapp Group
Sun Oct 21, 2018 11:57 am
Please add me. Grobbie 0829528781 Thanks
Brown
Country: Botswana
Vehicle: Mitsubishi Pajero 3.5 GDI 2002
Re: Whatsapp Group
Tue Oct 23, 2018 11:10 am
Please add me 0026773870534
Tunja
Vehicle: Pajero 3.2 SWB '2000
Re: Whatsapp Group
Thu Oct 25, 2018 9:55 pm
Please add me 0736090981 Thanx Ernie
MikaZA
Country: RSA
Vehicle: 2007 Pajero Gen 3 SWB 3.2
Re: Whatsapp Group
Fri Oct 26, 2018 10:56 am
Please add me: 0823166558
Oupa
Vehicle: 2008 Mitsubishi Pajero 3.8 GLS SWB
Re: Whatsapp Group
Thu Nov 08, 2018 11:17 am
Good day
Add me again please.
082 873 8103
Riaan
Oupa
4x4 Driving advice needed
Thu Nov 08, 2018 11:34 am
Good day guy's.
I have a 2008 3.8 V6 GlS, planned a trip in December to Clarens and Lesotho and intend doing some off road while there, my neighbour informed when using 4x4 I have to disengaged the ASC.
Is he correct or what do you recommend.
Furthermore I planned to service the vehicle(oil, oil filter ,rear axle, transfer case and auto box) but the dealer informed me the fuel filter is in the tank) vehicle's consumption is very high, and idling is very erratic, replaced the air filter just recently a few weeks ago.
Any pointers or advice will be appreciated.
Greetings
KurtG
Re: Whatsapp Group
Thu Nov 08, 2018 6:29 pm
Incorrect information has been provided.
On the Superselect one has 4 settings to choose from:
1. 2H
2. 4H
3. 4HLc
4. 4LLc
Positions 1 and 2 will engage ASC if wheel slip is detected, by cutting engine power. Here you can press the “ASC off” button to help you keep the engine power from cutting, but it not safe to do so unless you are prepared to control the potential high speed slide yourself.
Positions 3 and 4 when engaged will automatically switch off the ASC.
So if you are on the rough stuff, and you have selected the appropriate setting, there is no need to manually disengage the ASC.
Position 2 is open centre diff (70/30 front to back torque), position 3 is locked centre diff (50/50) so when you are on the rough stuff (i.e. worse than a gravel road) then you must select 3 or 4 (4 = low range).
Do not select 3 or 4 when on solid ground like tar or cement roads, you will create drivetrain windup and potential damage.
2H or 4H can be used on tar, no problem. Remember to engage N when moving to 3 or 4.
KurtG
Whatsapp Group
Thu Nov 08, 2018 6:30 pm
The fuel filter is part of the fuel pump I am led to believe, which is in the tank I think.
Who is online
Users browsing this forum: No registered users and 4 guests
Login  •  Register
