TOP GUNS
PIRI D-ID
Country: south africa
Vehicle: 2004 3.2 DI-D swb pajero
Re: TOP GUNS
Wed Aug 22, 2012 9:07 am
CATS wrote:Centurion Gearbox and Clutch. R22k will probably be all inclusive of a new Dual Mass Flywheel which is around R12k alone I believe. My whole story was about R12k which included the repairs. I bought the parts directly from Mitsu and gave it to the gearbox guys to fit. The pressure plate only was around R1500 iIrc.
thanx Cats i will give them a call
Against the grain, should be a way of life!
Brink_015
Vehicle: 1997 Mitsubishi Pajero 3.5 GLS
Re: TOP GUNS
Fri Sep 07, 2012 8:05 pm
Brink 1997 Gen 2 LWB Manual 3.5 V6 305000 305000
Been travelling too much by air and not using the Green Chilly (so named because at the current fuel prices it makes the eyes water and gives a burning sensation at the inlet and outlet)
Pajero Greetings,
"What if the hokey pokey is what it is all about?"
tonton
Country: RSA
Vehicle: 2007 3.8 GLS LWB (Gen 4)
Re: TOP GUNS
Sat Sep 08, 2012 7:09 pm
FINALLY! a change on the list!
Sorry Robin - Brink bumped you off.
Anybody else wants to update?
Pajero 3.8 GLS (A) LWB 2007 (Gen 4)
Pajero 3.5 GLS (M) LWB 2000 (Gen 2.5) SOLD
Pajero 3.5 GLS (A) LWB 1995 (Gen 2) SOLD
Gerrit Loubser
Re: TOP GUNS
Sat Sep 08, 2012 8:59 pm
Pretty cool that your mileage has to be more than 305k in order to have a shot at the Top 20. Perhaps we should start a "little league" for the next bunch of places, say 21st to 40th?
Our DiD is now at just over 275000 km and has given us absolutely fantastic service all the way. As far as I can recall we have replaced the brake discs, the oil pressure sender and the companion shafts at the back. Other than that it was all routine servicing.
Gerrit Loubser Image
Roy
Country: SA
Vehicle: Pajero 2.8 tdi SWB
Re: TOP GUNS
Wed Nov 28, 2012 4:02 pm
Roy, 1998 2.8 tdi SWB 300 003km on chassis and with engine
Paj3.2
Vehicle: Pajero 3.2 DiD 2002 (350 000 km)
Re: TOP GUNS
Tue Jan 01, 2013 2:37 pm
Paj3.2, 2002 Gen3 swb 3.2 Diesel, 384500km, 384500km
Jannybee
Contact:
Vehicle: 2000 3.0 SWB Pajero (blister fender)
Re: TOP GUNS
Thu Jan 03, 2013 6:34 pm
2000 Gen 2.5 SWB 3.0 petrol 320000km and I'm still in love with it :D
The journey is the destination
Contact:
Re: TOP GUNS
Sat Jan 05, 2013 8:26 am
Just to keep my details updated as well. Although it seems I am far from the Top Guns list. But in 3.2Did terms I must be in the top 10 or so?
I am now on 282452km on my 2001 3.2Did manual on engine and drivetrain.
Engine still original but I have done a lot of preventative maintenance like rubber pipes etc over the years and also replaced injectors on 100000km and intend doing so again on 300000km. Previously I had to replace wheelbearings, side shaft clips on the rear, timing chain guide, oil pressure sender unit, brake booster under warantee recall(but mined failed before then as well). On 280000 I had to replace the Dual mass Flywheel after it failed catastrophically on my December tour without any warning and decided to do the clutch and pressure plate etc at the same time. I previously had the clutch alone done when I had the gearbox out to fix a worn clutch retaining plate. I stuck with the original Mitsu parts and did not consider a solid flywheel conversion. Parts were readily available in South Africa and the DMF alone was R14000. By the way it weighs 28kg if you ever need to give the weight to anyone to get it couriered to you.
The rest of the repairs and maintenance was either self inflicted or normal service items as far as I can recall.
NicoNelton
Vehicle: Pajero LWB 1998 3.5 litre V6
Re: TOP GUNS
Sun Jan 06, 2013 7:12 pm
What about the oldest Pajero with the lowest kilometres? For example, I have 3 1998 Gen 2 LWB 3500 GDI with 82,580, 92,859 and 105,204 kilometres, respectively!
This could make some jealous!
tonton
Country: RSA
Re: TOP GUNS
Thu Jan 24, 2013 10:58 pm
  • Paj3.2 promoted to No. 6
  • JohannK new no 18 (info from High Mileage Club)
  • Jannybee - new no 20 at 320000 km...
Login · Register
Latest Posts
Login  •  Register
