High Mileage Club (>150000km)
SimonB
Site Admin
Vehicle: 2015 Pajero Sport
Wed Nov 11, 2009 4:35 pm
Christo's post on 3.2 DiD longivity prompted this.
What model / year is your Pajero?
How much mileage had your Pajero done?
Is it the original motor?
Any major work?
I'll start
What model / year is your Pajero? 1996 Gen2 3.5V6
How much mileage had your Pajero done? 192000km
Is it the original motor? Yes
Any major work? New Clutch and Water Pump
Pajero Sport 2.5
Gerrit Loubser
Wed Nov 11, 2009 5:33 pm
What model / year is your Pajero? 2003 DiD GLS LWB A/T
How much mileage had your Pajero done? 291800 km
Is it the original motor? Original Motor (and other major components)
Any major work? Very few hassles (mostly only routine servicing and replacement of wear items)
  • Rear brake discs replaced every 90000 km (although the last set run for almost 114000 km and were still fine)
  • Electric aerial mast rack stripped at 187000 km (New mast cost R463)
  • Leaking engine oil pressure sender replaced at 190000 km
  • Leaking companion shaft seal on LHS rear. Companion shafts/seals replaced both sides around 240000 km
  • Erratic temperature gauge (this seems to come and go :? )
  • Battery changed every 2 years. Finally fitted a nice and big 650 CR (90 Ah) unit.
  • Alternator belts replaced twice
Sadly, our Pajero was traded in on a normal sedan at 291000 km. Having two four wheel drive vehicles just didn't make sense...
Last edited by Gerrit Loubser on Thu Jun 26, 2014 9:41 pm, edited 9 times in total.
Reason: Updated info added
Gerrit Loubser Image
4ePikanini
Contact:
Wed Nov 11, 2009 6:20 pm
What model / year is your Pajero? 1993 Gen2 3.0 V6
How much mileage had your Pajero done? 270'000km
Is it the original motor? Original completely rebuilt 1500km ago
Any major work? Complete overhaul
Marius Fourie
MY DIY WEBSITE
pa
pajero101
Thu Nov 12, 2009 5:42 am
What model / year is your Pajero? 1998 2.8Tdi SWB Glx
How much mileage had your Pajero done? 252'000km
Is it the original motor? Yes, all Original
Any major work? Not that I know of, Done the starter last week.
MR
MR2-Blue
Thu Nov 12, 2009 5:55 am
What model / year is your Pajero? 2004 DiD GLS SWB
How much mileage had your Pajero done? 163000 km
Any major work? Not to my knowledge and since I own the car
4ePajero
Vehicle: 1989 Pajero LWB
Thu Nov 12, 2009 9:20 am
What model / year is your Pajero? Gen1 1989
How much mileage had your Pajero done? ±340 000
Is it the original motor? No
Any major work? Yes:
Di-D transplant :D
Steering components (wear)
Gen2 front brakes transplant (by choice)
HBannink
Contact:
Vehicle: Pajero gen2 3l lwb
Thu Nov 12, 2009 10:55 pm
What model / year is your Pajero? 1995 3l lwb
How much mileage had your Pajero done? 350 000
Is it the original motor? No Jap import. Popped a heater pipe and did not notice, cost me a motor. Bottom end ok but heads shot.
Any major work? Rebuilt front cvs and brakes all round, New ome suspension system.
Reason: Time moves on and ks covered also climb
Henk Bannink
AndreBenson
Fri Nov 13, 2009 7:27 am
What model / year is your Pajero? 1997 3.5V6 LWB
Any major work? Clutch, all pipes(so far), and it seems the head one of these days
jbeez
Vehicle: 2005 3.8 GLS
Fri Nov 13, 2009 2:15 pm
What model / year is your Pajero? 1996 Gen2 2.8tdi LWB
How much mileage had your Pajero done? 195000 km
Any major work? OH YES
1. Timing chains broke on 155000km
Replaced the head (cracked) as well as small and big ends, rings, water and oil pump, camshaft,ect
2. Starting problems (+-180 000km)
Replaced primer pump, reconditioned dieselpump and reconned startermotor
3. Coils shot (+- 180 000) Ended up in replacing the deisel tank as well as a set of IM coils found at a scrapy yard
4. Front suspension (CV's and idler arm) is due next.
Johann Bredell
SimonB
Site Admin
Fri Nov 13, 2009 2:17 pm
jbeez wrote: Replaced primer pump, reconditioned dieselpump and reconned startermotor
Johan
How much did the recon starter motor job cost you?
Pajero Sport 2.5
Who is online
Users browsing this forum: No registered users and 3 guests
Login · Register
Login  •  Register
