My 2013 DID,c also had the dash rattle. I took the dash board apart and re tighten/ glue every loose wire and bracket! No change
After a lot of sweat and tears I found out that it was the plastic where the windscreen and dashboard come together that rub against each other specially when outside air temp is cold! (plastic aircon ducting rub against lower dashboard surface and windscreen)
I pressed a piece of black foam in between the width/length of the dashboard and the windscreen deep enough in so that you can not see it, and that was the end of the irritating rattle noise
Pajero DID,c 3.2 SWB Exceed Dashboard Rattle
- KurtG
- Country: South Africa
- Vehicle: 2014 Pajero 3.2Di-D SWB
Post
Re: Pajero DID,c 3.2 SWB Exceed Dashboard Rattle
I can fix it permanently in 5min if you would like to have the cable ties installed, we also do brackets that stabilize the whole centre section and prevents movement. Let me know if you're interested.Klause wrote:My 2013 DID,c also had the dash rattle. I took the dash board apart and re tighten/ glue every loose wire and bracket! No change
- KurtG
Post
Gen4 Dash Rattle - Statement from Mitsu SA
https://r.tapatalk.com/shareLink?share_ ... are_type=t
Kl
Post
Thanks I am happy like it is and I am to far from you...Hartenbos
Kl
Post
i would like to mention:My impression of the structure and mountings of the Pajero Dashboard when I took it apart is, it looks strong and the mounting points is also good!!!! The only flaw is the plastics of aircon ducting and dashboard that rub against each other!!!! I based my opinion on experience of car re building and restoration threw the years. What I basically want to say, the dashboard is not going to fall apart!!!!!
- Roelf_le_Roux
- Contact:
Post
Re: RE: Re: Pajero DID,c 3.2 SWB Exceed Dashboard Rattle
That has always been the general opinion. It doesn't threaten to fall apart and the movement isn't necessarily the cause of a rattle. The brackets address the movement and the cable tie fix sorts that "windscreen" rattle out.Klause wrote:i would like to mention:My impression of the structure and mountings of the Pajero Dashboard when I took it apart is, it looks strong and the mounting points is also good!!!! The only flaw is the plastics of aircon ducting and dashboard that rub against each other!!!! I based my opinion on experience of car re building and restoration threw the years. What I basically want to say, the dashboard is not going to fall apart!!!!!
- Tmullet
- Vehicle: Pajero Exceed 2014
Post
Hi! I have a 2015 Pajero Exceed with dashboard rattles. Anyone do the dashboard mod in Durban area?
Ettienne
Sent from my SM-N920C using Tapatalk
Ettienne
- KurtG
Post
Unfortunately we don't have anyone in DBN but we may be able to help out when one of us travels down there. I will chat to John.Tmullet wrote:Hi! I have a 2015 Pajero Exceed with dashboard rattles. Anyone do the dashboard mod in Durban area?
Ettienne
jo
Post
Hi Kurt,
I'm in the joburg area - if you're still offering the service how can I get hold of you ? very keen to get my Dash rattle sorted. New to this forum so unf don't seem to have the ability to PM yet.
Jon
Jon
- KurtG
Post
Call me on 083 six oh 4 8455, I'm available this weekend.jonnie105 wrote:Hi Kurt,
Jon
