Vacuum pipe route
Andre L
Vehicle: Pajero 3.2 diesel manual
Vacuum pipe route
Wed Jan 03, 2018 11:14 pm
Please help. Can somebody assist me by explaining the route of the vacuum pipes connected to manual gearbox. Where does the vacuum come from ? Route to operate the locks on the rear diff and 4x4 box and super select.At which point does it connects to the vacuum supply. My vacuum pipe to engine compartment is missing.
Thank you
Andre
Andre L
vacuum pipe route
Wed Jan 03, 2018 11:23 pm
I asked for information on vacuum pipe route and forgot to mention the model. It is for Pajero 3.2 did 2001 manual.
Andre
Morsjors
Country: RSA
Vehicle: 2006 Nissan Hardbody, 2001 Gen 3 SWB
Re: Vacuum pipe route
Tue Jan 08, 2019 11:05 am
Dit is presies wat ek ook wil weet . Ek weet dit begin by die oordrag ratkas en loop tot voor by die vacuum solenoid onder die "airbox" en dan van daar na die vacuum tank wat dan die "freewhweel clutch " werk. My kar se pyp is erens tussen die ratkas en die solenoid af maar waar , dit is die vraag. die probleem is dat daar nie genoeg spasie is om te kan sien wat aangaan nie.
SnaRf
Vehicle: Mitsubishi Pajero IO, 1.8, 1999
Sat Jan 12, 2019 1:38 pm
Not 100% an answer to your question, but this may help.
http://4wd.blogeasy.com/article.view.ru ... eID=318776
Who is online
Users browsing this forum: No registered users and 3 guests
Login · Register
Login  •  Register
