Front wheel green lights flashing !!
diesel&dust
Country: south africa
Vehicle: gen 3 pajero lwb
Tue Mar 12, 2019 9:29 pm
Hi fellow pajero owners ,i have a 2002 3.2 did
when selecting 4h my front green wheel lights keep flashing
it definitely engages 4x4 hi ,
the vacuum switches are 100%
all pipes,tank and actuator are 100%
4x4 switch on front axle are also 100%
which part can be the culprit ? gearbox switches ? which one ?
PLS ,any advise will be much appreciated .
jimsutt
Country: Australia
Vehicle: nissan patrol
Re: Front wheel green lights flashing !!
Wed Mar 13, 2019 12:33 am
diesel&dust wrote:Hi fellow pajero owners ,i have a 2002 3.2 did
I know my Pajero is a later model but I have to take my foot off the accelerator to a few seconds and the lights go solid.. It's probably to take the pressure off the gears. Hope this helps.
Sent from my SM-G900T using Tapatalk
h_hezzah
Country: Egypt
Vehicle: Pajero NM 2001 3.5 Aut LWB
Sun Mar 17, 2019 1:09 pm
Same here, you have to unload the front diff gears.
Same applies when disengaging.
tsblack
Vehicle: 2001 Pajero 3.2
Mon Mar 18, 2019 12:48 pm
Hiya
This has happened to us in the past with our 2001 SWB. After much frustration we found it to be the front solenoid which just needed a clean, some working and re-lubrication.
We almost stripped everything else down thinking that the front solenoid actually looked fine.
-Thomas
h_hezzah
Country: Egypt
Sun Mar 24, 2019 2:05 pm
-Thomas
Do you mean the 2 solenoids, or the actuator that sits at the front differential?
As far as I know, the solenoids have nothing that needs to be lubricated.
Who is online
Login · Register
Login  •  Register
