macjohnw
I did it - 3.2 DID Free Flow exhaust
So I had my brother change the still original factory exhaust system to a free flow one. The pipe was a dia60mm and I left it like that - no need to change to a dia63mm. He took out the catalytic converter and replaced it with a resonator. The large middle off-center box was changed to a free flow one but he left the small back box as is seeing that it is a free flow box already.
Traveled 650km with it today and can say that:
*Better drive-ability through the lower rev ranges - it feels a bit more lively and responsive
*Seems like the fuel consumption also improved somewhat, but will confirm as the weeks go by
*There is a bit of a "growl" when idling (which sounds nice :twisted: ) but no difference when accelerating or driving.
*The exhaust fumes do smell a bit more now that the catalytic converter is removed
In my books an improvement.
Jur
Re: I did it - 3.2 DID Free Flow exhaust
It sounds good.
Did you cover more miles since?
Do you have part numbers of the boxes that you used?
macjohnw
Hallo Jurie,
Ja, ek het so 2 weke terug n' freeflow deur my broer laat opsit. Hier is wat ek gedoen het:
* Het die catalytic converter uitgehaal en vervang met n' klein resonator.
* Die groot boks is vervang met een van dieselfde grote, maar n' freeflow boks.
* Die agterste boks is net so gelaat aangesien dit reeds n' freeflow is.
* Die bestaande pyps is dia60mm en ek het dit so gelaat.
Dus hoef jy nie die hele sisteem te vervang nie, slegs die catalytic converter en middel boks.
Ek het n' groei in krag gevoel en sien ook n' verbetering in brandstof verbruik. Die kar is meer responsive en trek beter. Die turbo op die diesel enjin demp die geluid, dus raas dit nie soos n' petrol freeflow nie. Mens hoor so effense grom as hy idle,maar kom dit amper nie agter nie. Die enigste negatief is dat jy wel die diesel gasse meer ruik as dit idle agv die verwydering van die catalytic converter.
My opinie, gaan daarvoor, ek is tevrede. Laat weet wat jy besluit het.
Groete
John
GertM
Any update on this, John? Economy, power?
macjohnw
GJM,
I can feel a bit more power when accelerating and when driving int he mountains and get about 9-10km/l. Previously the car was a bit more sluggish going up hills/mountains and gave about 7-8km/l.
So yes, worth it in my books.
latest feedback on this?
I'm keen on deleting the centre big box that compromises ground clearance.
4ePikanini wrote:latest feedback on this?
Would also liek to have that big box otu of the way as it looks way to vulnerable for rocks.
Riku
Echo 4 2011
Skillie
Will it be possible to give a price indication for this conversion?
A TD barely needs a silencer. The turbo smooths out the exhaust impulses.
Dump it!
