Hi Paw-by-Paw
I concur with the above as well, however on the whole debacle of honing, it is not something to be taken lightly. The issue with only honing a sleeve and replacing rings alone, is that if the company doing the honing is not carefull, and have measured the IDs perfectly, they han hone past a certain tollerance. This will affect the ring gap and may even lead to piston slap. Same story on the bearings, especially on the crank. Just fitting new bearings may not be all that much gain in having new parts fitted, as the crank may also need polishing. Now the same story as with the sleave honing applies, take off too much and the specifieed clearances become too much, resulting in failure down the road. This is the reason why so may "rebuilds" fail, as e incorrect processes were followed.
So, before I get too many reponses on my statements above, let me put ts out there: I am a qualified Motor Fitter and Turner(from the old days), have been my business for 12 years -- many years ago though
My advise is that if you decide to go the full road of reconditioining the motor, go all the way and have the cylinders rebored, fit oversize pistons etc. And do the same with the crank and conrods etc.
Since you are in Secunda and not too far from Centurion, you could have the engineering done by Andre at Centurion Motor Engineering. I will even help with the assembly if you want.
Hope this helps
Johann
