After Decembers’ long holiday is gone, it was the first time I could take my Pajero out on the open road for a distance longer than 100km. I noticed an excessive oil pressure reading on my MadMan EMS2 unit fitted to my vehicle.
Often when driving (esp when overtaking) the pressure exceeds 800kPa or 8 bar (to which my alarm is set) which seems quite high. The service manual says that the pressure should be between 2.94 and 6.86 bar at 3500 r/min and above 0.29 bar at idle or 700r/min. At 3500 r/min mine read in the area of 7.5 bar.
I phoned Mitsubishi, and they say that it is fine running at those pressures, however I am worried of popping an oil filter or blowing an oil seal somewhere on the motor. I also enquired if a pressure relief valve is stuck closed, and the mechanic said the pressure would always read very high then?!?
I have also just changed my oil filter (GUD) and oil as I thought it could be a blocked oil filter, and the values dropped slightly. I have also put in Castrol EDGE 5W-40 (specified by Castrol technical helpline)& which is a fully synthetic oil, hoped it would help.(There is no Caltex DELO 400 anywhere near me!
Any suggestions would be valued! Also is there anyone else who constantly monitors their engine oil pressure as I do so that I can compare?
