Re: Gen3 3.2 DiD Oil Change
Bush Basher wrote:Hi Julle.
Baie help volle onderwerp. Thanks!! Ek Wil my 2001 DID 3.2 die naweek doen.
Het Castrol GTX Turbo Diesel olie gekoop. Sal dit fine wees?
Some say it is fine.
I would not.
There are just to many reports of sludging with Castrol oils (is that the correct spelling ? :twisted: )
Why not spend a bit more money on an oil about which there is NO argument, such as Caltex Delo400 or Shell Rimula.
MThompson wrote:So the sump plug must be installed before filling? :lol: kidding....that is common sense.
Um. Ek moet bieg, my golf 3 gediens en toe ek hier by 9l olie kom en dit wys nognie op die dipstick nie......
Duur en morsige les, nou diens ek my voertuie kaalvoet sodat ek die olie kan voel :mrgreen:
Jakes
[quote="MThompson"]Report
Install sump plug and new washer....torque to 39nm......must say...this is tighter than what I would have done without a torque wrench.
Ek het nie self die torque spec van die sump plug nie maar is 39 Nm nie dalk bietjie hoog nie.
Ek het spec's op ander voertuie en hulle wissel tussen 20 en 30 Nm.
Maar 9 Nm ekstra sal seker nie saak maak nie.
Re: Re: Gen3 3.2 DiD Oil Change
Jakes wrote:
MThompson wrote:Report
Ek sal nou nie weet nie, maar dit was so in die manual....so ek volg maar instruksies.
Bwahahahaha, dis funny. Kan glo dit was n gemors.....jy sal noooit weer daai fout maak nie?
Ok, second time around not so lucky.....stripped sump bolt. Now I really don't trust midas torque wrenches.
I need some advise please....is this a serious problem, as in fix before driving, or can I at least drive to work and then indie (approx 50km) or is it ok to drive to barbertin this weekend and sort when I get back? Will check oil levels all the time, but I'm afraid to drive at all.
Any idea what the solution is to this mess. Replace sump? Cost involved?
Why o why did I want to change the oil before the barberton trip........
cloyd wrote:Hi guys,
By changing the oil in your engine yourself can/will/may be the entrance to bigger things. Well done for taking the first step in the right direction!
I shall make the following offer to any first time Pajero DIY owner that is willing/able to visit my house in Pretoria: I will asist you in changing oil(s) and filters (basically guide you - you will be doing the actual work and I shall instruct you on how to do it). You can also include gearbox and diffs oils if you like with the one proviso: no pre-stripped bolts or plugs.
Interested owners can contact me anytime.
Cloyd
Cloyd,
I'd like to up the offer if it still stands ? I'm new enough that I cant send a PM yet :(
I was going to book at mitshpro this morning when I saw the post.
I need to do service 150k service - oil/filter + but it seems I also need to do the front and rear diff and transfer case - these should have been done on 135k km but seems they weren't
Herman 6609
What oil is the best to use on 3.2 did,synthetic or 15w40?
Herman 6609 wrote:What oil is the best to use on 3.2 did,synthetic or 15w40?
Synthetic oil is overkill and not necessary for the 4m41 motor, just stick to 15w40 caltex DELO 400.
Nicholas Gibson
Corsa 1.4 Club (swambo)
Cape Town
Herman 6609
Thanks again Nick
