Hi all,
I'm busy changing engines after my previously one popped.
My Pajero is an auto but the donor engine came off a manual box.
The Mac phoned me just now stating that my old engine had 2 temp sensors in the engine bay while the new engine only has one sensor.
So he now has one wire hanging loose.
Please let me know if anyone has an idea why there are a diffrence in the amount of sensors on the 2 engines which should be identical and where the extra wire should go.
Pierre
Hi guys - me again,
Now that I have the car back I could take better pics.
See the extra wire in pic below.
I have the car booked in at the Dealers on Monday but would like to know what you guys think
Pierre
Pierre
hi not sure on the wire issue but check on the forum lots of info just curious on what they charged for a motor replacment?
Mitsu is known to have separate cooling sensors for
- temp gauge in the dash
- temp sensor for ECU (engine and/or gearbox)
- A/C system temp sensor (A/C cuts out if coolant is too hot)
So generally Mitsu engines have 2 sensors for manual and 3 sensors for Auto..... or is it 1 sensor for manual and 2 sensors for auto.
Not entirely sure and I don't own a pajero to check.
Stupid question Where is your old engine and why did your mac not do a comparison check You old sensor must stil be on the engine He obviously just rip every thing off without marking what goes where But i think that is water under the engine cowling
Try trace your steps back to the old engine or grt another friendly owner to open his pajero bonet
According to your info it looks like a 1999 petol it looks like I think one may be available at work Will look and take a pic
Email me at snrrags@gmail.com if you want me to go ahead
Hi, the old engine is still on the workshop floor and we took notes of everything. There is a difference between the 2 engines of the number of sensor but that seems to be OK. I'll just drill and tap the sensor for the old engine into the donor one. Should be ok.
Pierre
Pierre
Around R3500clinton wrote:hi not sure on the wire issue but check on the forum lots of info just curious on what they charged for a motor replacment?
Thanks a span you guys. It turned out that this issue and my other problem was related ("Kick down" post). My overdrive did not work and it seems like this sensor controls that.
So I earthed the extra wire and the O/D kicked in!!
I'll get the sensor drilled and tapped in tomorrow.
Thanks again
Pierre
Thanks again
Pierre
