Those "Crickets" in the engine bay
After reading CATS's saga I am very concerned that something may be brewing with my Paj as well. There is a whistling noise from under the bonnet only when the motor is being pushed very hard on an incline with a heavy load such as a caravan in tow.
It had been described by other members before as some thing that sounds like a petrol engine pinging. The best description so far was that it sounds like a bag of crickets having a ball.
Speculation I've heard was that it could be a cracked manifold or intercooler. Some mechanic also said it may be the waste-gate blowing off excessively high pressure built-up under those conditions. I do not have an EGT gauge so I am worried that the EGT is getting out of hand and is causing a kind of detonation. What is your experience with this problem to date? I have not yet seen a good explanation of this noise. Have you? Why does this only happen under extreme engine loading? And why no immediate permanent damage.
Willie from Jo'burg
Re: Those "Crickets" in the engine bay
Bigwill
Dont let my incidence cause you worry. Many more Dids running around with higher mileages than mine. Trouble free. I would not worry about EGT as I NEVER experienced any high EGT ever! The Did engine ECU is pretty good in controlling that I think.
