Troubleshooting 4x4 Super select lights
4ePikanini
Contact:
Country: South Africa
Mon Jul 13, 2009 8:01 pm
I can't edit my old DIY - My images are broken there so here it is re-hosted
From fiddling around at all the systems I thought I should put it all together in a DIY write-up
If you have a mechanical problem ( flashing lights) then you should have a look here
This is merely my electrical fix as my lights wasn't working properly
NB: Please go through the whole thread before starting so you have a good idea of what to expect and where to be careful.
Gain access to the 4x4 lights control module
It is easy to access if you remove the front panel ( 2 screws on top part - look from a low down angle ) and the radio
NB : remeber to perform these tests with the ignition in the correct position
** don't mind the green and red marks as this was my troubleshooting findings **
should you pass all these tests then you need to check the bulbs - further down the page
If you don't pass then check the working of your lights by grounding the wires going to the transmission switches
- If you don't get these results, you have a break in the wiring and need to trace the fault or replace the wiring
NB: remember to have the ignition in the 'ON' position
***I did not comment on the rear wheel lights as they should always be on with the ignition.***
I managed to fix my number 5 switch by turning the washer around as the previous person tightened it so tight that it deformed the washer slightly
NOTES on number 5 switch
* It is a pin type switch
* at rest position = no continuity between thread and wire
* between 1mm - 4mm pin pressed into switch = continuity between thread and wire
* pressed in further than 4mm = no continuity between thread and wire
Thus the washer thickness is of extreme importance
NB : Number 1 switch is a ball switch
To gain access to the bulbs
SWITCH THE IGNITION OFF! (or disconnect the battery as a better option - remember your radio code and alarm repercussions if you disconnect the battery)
remove the cluster cover - 2 screw in front on the sides and 1 screw at the back underneath a little cover
NB : you need a stubby screwdriver to get to the back screw
NB : throw a cloth over the back vents as a screw down there will spoil your evening
slowly remove the cover and disconnect the wiring of the switches ( fogs, hazards, *cruise, rear window heater ) at the back of the cluster - be careful as you don't want to damage any wiring
NB: ALL the connections have some sort of button you need to push before taking out the wiring plug
Then you need to remove all the small screws holding the cluster cover on ( Not the 3 big ones yet )
NB : a good magnet tipped screwdriver is crucial - a screw dropped is not fun!
once those screws are out you can gently remove the plastic cover THEN the black cover THEN the clear plastic over the 4x4 lights and THEN the black film over the 4x4 lights - it should come off VERY easily.
NB: You cannot replace the bulbs at this point as you need to gain access from the back - Trust me on this one :)
You can now unscrew the big three screws to loosen the cluster.
I pulled the right side of the cluster slightly forward to loosen the 2 connectors there first
NB: be gentle as the wiring board at the back is actually a thin film ( see picture below )
I then GENTLY loosened the other side connectors
NB: There are 2 big connectors left
NB: There are 2 big connectors right
NB: a single spade type connector ( not marked in the image ) on the left
NB: the speedo drive is just loose and should EASILY slide out
NB: ONCE AGAIN THE CONNECTORS HAVE BUTTONS TO PRESS TO GET THEM OUT - IF YOU FORCE YOU WILL BREAK THE WHOLE CLUSTER - I WARNED YOU!!!!! :)
You can then gain access to the bulbs with the cluster out - simply give a slight twist clockwise ( I found needle nose pliers useful here )
The bulbs simply pull out of the black plastic seater with a bit of persuasion ( i wish i had rubber tipped pliers as it took ages trying to pull it out with my thumb and fore finger - IF YOU TRY PLIERS THEY WILL POP - I WARNED YOU AGAIN! )
You can then replace them and put everything back together ( ala haynes - 'assembly is reverse of removal' )
NB: I just swapped in the A/T temp and diff lock bulbs as I don't have either ( You can try the cruise control bulb as well )
From the mitsubishi workshop manual
4e
4eJunior
Re: Troubleshooting 4x4 Super select lights
Tue Jul 14, 2009 7:31 am
Nice work Marius !! :D
.. and great tutorial :idea: :idea: :idea:
How far is the enjin ??
4ePikanini
Contact:
Tue Jul 14, 2009 8:53 am
Thanks boet
I thought it would be nice to give some feedback on how to go about this as there is very little info on the issue ( lots on the flashing lights though ) even though it seems to be a common problem.
RE engine : I'm resisting the urge to phone and check on the engine as I actually only want it back at the end of August for financial reasons.
SimonB
Site Admin
Vehicle: 2015 Pajero Sport
Mon Jul 20, 2009 4:37 pm
Marius
Have you worked out where to get spare bulbs at all?
Pajero Sport 2.5
4ePikanini
Contact:
Mon Jul 20, 2009 5:25 pm
SimonB wrote:Marius
I haven't really looked as I just used the ones that I don't use ( A/T fluid temp & diff lock )
The actual bulb comes out of the black plastic seating with a pull - the bulb looks like a standard bulb
with plastic
bulb removed
Family_Dog
Mon Jul 20, 2009 6:19 pm
Diesel Electric stock those, and probably Midas and Autozone as well. They are quite commonly used as dash board lghts.
-F_D
White Fang: 1999 2.7i DC Raider 4x4
BullDog: 1987 4Y-EFI 2.2 DC 4x4
PraDog: 1998 Prado VX 3.4
HounDog: 2000 2.7i SC 4x4
HotDog: 1986 3Y Hilux SWB 4x2 - Sold!
One Staffie, One Jack Russell, One Ring Neck Screecher, One Gold Fish
sy
sybie99
Mon Nov 29, 2010 8:36 am
Hi guys
Last week I bought myself a 1999 Gen 2.5, very happy with it BUT, yesterday put it in 4H and the green 4H lights just keep flashing.
I have looked at the troubleshooting and not being the most technically or mechanically adept person thought that maybe it would be best to just take it to a Mitsu dealership and get it checked out. I did try the basic things such as reversing in a straight line which did not solve the issue.
Slightly worried that it could be a major issue with the transfer case, could this end up being an expensive problem?
Just annoyed that a vehicle I just purchased is already giving it 1st problem
Seb
4ePikanini
Contact:
Mon Nov 29, 2010 8:37 am
if you bought it a week ago, make it the previous owner's problem.
sy
sybie99
Mon Nov 29, 2010 8:57 am
Wish I could, but dont think he will be too interested, voetstoots...
4ePikanini
Contact:
Mon Nov 29, 2010 9:29 am
they get sticky if not used for long periods. Try and move it back and forth between 2h and 4h (with forward and reverse motion in a straight line) numerous times, I have heard of some people having it "fix" itself after up to 40 tries.
My gen2 was very sticky when I bought it but when I used it as company vehicle on the dirt road (engaging 4h on a daily basis) the 4h selection became almost instantaneous after about 2 weeks of on/off use.
Return to “Drivetrain”
Login · Register
Login  •  Register
