markus_fourie
Installation of 24 valve 3000 engine, Low mileage import
Quite a complicated installation which requires a lot of modifications. The engine mounting brackets were altered to accept the bigger ones coming with the new engine. The engine oil filter was also moved to a place next to the engine and .......much more.
Spitronics provided the engine management system, with Precision Performance in Montague gardens doing the final tuning on the dyno.
The engine now runs and performs beautifully - hoping to give the 1997 Pajero SWB a new lease of life.
Re: Installation of 24 valve 3000 engine, Low mileage import
dr3am3r
Pictures or it didn't happen
markus_fourie
Ok, you have asked for it. See attached photos.
X indicates the original position of the oil filter.
Vacuum censor
Vacuum censor
Intake manifolds, can you spot the difference?
See new air filter, old one did not fit in
Bosch lamda censor in exhaust
Relocated oil filter
Egine bay
Egine bay
Relay box + fuses for Spitronics system
36T + magnetic pickup (origin of timing pulses)
Series II Pajero SWB, 1997
nashief
Hi who did the wiring and tuning of the spitronics?
