Josef9177
Re: Gen 4 DID NO POWER
Update from mitsu!! They have checked everything from SCV, diesel pump,injectors, barometer pressure sensor and they all are ok. Now they are checking the intercooler....
Josef9177
Wht else could be wrong car has been lying there for two months and the issue still not diagnosed
Very strange. Maybe the ecu itself?
Josef9177
Maybe would check and update
Josef9177
Mitsu India is hopeless..the dealer say it takes two months for them to get the Ecu imported. Also they are not 100% sure it's the Ecu problem.
So I took delivery of the car today and gave it to another famous imported car garage here....
Josef9177
Still no hope. I was told today by a car expert that it could be a gearbox problem.
Josef9177
In park and neutral the car builds revs as it should but on drive it doesn't rev.
Sounds gearbox related to me as well. Have you tried to get any possible fault codes with an OBDII bluetooth device and a app like Torqtune on your smartphone?
Maybe that will give some pointers?
Josef9177
Thanks cats!! never knew about that. Will try it. So the pajero 4 is obd2 compliant? I'm using an iPhone 5. So is this should I be buying ? http://pages.ebay.com/link/?nav=item.vi ... ID=EBAY-US
Josef9177 wrote:Thanks cats!! never knew about that. Will try it. So the pajero 4 is obd2 compliant? I'm using an iPhone 5. So is this should I be buying ? http://pages.ebay.com/link/?nav=item.vi ... ID=EBAY-US
Yes. In SA at least it seems that thr gen4 is OBDII compliant where the gen3 was not.
