Yes thanks Nismo I have read a number of posts from Marius while researching this lot. He is very dedicated and very helpful. Thanks Marius from all of us.
Ok, so while researching this lot I came across some info.
It appears that overseas Gen3 were replaced by Gen4 but we only got new the new models about a year later than most overseas counties. This has been a common trend amongst SA manufacturers and the plus point is that hopefully all the gremlins are sorted out in the delay year. On Gen4 the '08 had an engine system pretty much the same as the Gen3. Common rail yes but normal type turbo. It appears (and any one is free to comment) that overseas '09 Gen4's went to one of those special turbo's with variable control in the exhaust turbine housing. It appears this is what the '10 140kw motor uses as well. The overseas '09's also have DPF's fitted and these 3.2 Didc's put out 129kw!!. My '09 does not have a DPF nor one of those variable type turbo's and I am happy about that 'cause I have found those inclined to be finicky (Marius will say because of the diesel!!! - hey Marius you hate the SA stuff!!!
