Theodorus1
Oil change and gearbox oil
Which is the most suitable oil for gear box and is it ok if i do it my self or better to take it some where
Stranger
Re: Oil change and gearbox oil
Auto or manual ?
I have to admit that my Indie will only use the Mitsu supplied oils and coolant.
Theodorus1
Outo
Only use genuine Mitshibusi oils... Diaqueen in diffs and gearbox
Llewellyn
1995 Pajero SWB 2.8TD
1996 Delica 2.8td
manual box - gl-4 spec
auto box - dia queen from agents
transfer case - gl-4 spec
front and rear differentials - gl-5 spec
rear LSD on gen2 - add LSD friction modifier
My experience - Stick to Mits DiaQueen in the diff as well (particular rear diff in Gen 3)
Also see the specific detailed post about "flushing" the auto box properly...
Llewellyn
1996 Delica 2.8td
Theodorus1
Thank yoh im just gone take it to freek rather
8-) Still insist on using genuine oils...
Llewellyn
1996 Delica 2.8td
