Gen 4 - Rear view mirror loose.
Since our return from Namibia in Dec my passenger side rear view mirror seems to be loose - The mirror glass itself vibrates while driving, which is quite annoying. :x
Anybody else had this? Something broken inside which I can fix? How do I get the mirror opened up?
Johan
Johan
VW Tiguan 2.0TDi (Tar ;))
Bushlapa Boabab 4.2 in tow
Re: Gen 4 - Rear view mirror loose.
I'm following this thread. Both my Gen4's rear view mirrors also vibrates while driving. Very annoying.
Sent from my BV8000Pro using Tapatalk
Olaf the 'friendly' snowman
2010 Gen4 Pajero GLX LWB 121Kw
OME Suspension / Ironman Shocks
Frontrunner Roofrack
Continental CrossContact 265/65/17
Also following. My gen 4 Pajero driver side RV mirror glass is vibrating. The d(st)ealership said the whole rear view assembly needs ro be replaced and gave me a ridiculous quote...
Sent from my SM-N920C using Tapatalk
If someone can give some guidance on how to open it up (without breaking anything! :( ), it would be appreciated.
I can then see what is going on!
Johan
You just had to give me this challenge didn’t you? 🤣.
There seem to be two ways to get the unit off:
1) from underneath there is a small plastic cover which exposes three screws. I tried to loosen them but they are tight and the angle doesn’t help so I gave up. Maybe with the right screwdriver it will be possible.
2) inside the car, simply pull the “tweeter” holder off, it attaches with one plastic plug, easy removal. Then there are two bolts holding the mirror on (at least I could only see two). The problem is you will need to remove the door panel to get to them.
Have a look at the pics I just took (they seem to have loaded in reverse order):
The attachment IMG_4035.JPG is no longer available
KurtG wrote: You just had to give me this challenge didn’t you? 🤣.
I knew you'd fall for it!! :twisted: :D
Thanks Kurt - Will give it a try this weekend!
Johan
