macivorj
Re: Gen 2 6G72 3.0 12V problem
I know this was a while back, but here is hoping.
I have a 1998 Pajero SWB 6G72 3.0 12v GLX, which I am having similar engine issues with -- I am having to rebuild too-- I have 2 engines and trying to use best from both to make one good recon engine from. I have one block stripped and ready for re-bore, cams and crank also ready for recon.
TSnyders specifically -- please if you could PM where you sourced your rebuild parts (and brands you would/would not use) and any details of those engineering firms who assisted you. I see you did crankshaft recon did you recon cams too? If you could share a list of all the parts you ended up replacing (or should have replaced) and any lessons you learned would do different if you had to rebuild one of these engines again. Also if you could share how the rebuild has shaped up and if it was worth it -- how is the engine running now.
Any assistance and info would be greatly appreciated.
Many thanks.
