Testing Super Select ECU and gearbox switches
toppie4x4
Country: RSA
Vehicle: Pajero iO 2002 2 Lit
Fri May 25, 2018 5:22 pm
Did some research on the flashing lights - super select system and compile a diagram. This is for the Pajero iO but should work on all Pajero's.
super select ECU test.pdf
(228.76 KiB) Downloaded 93 times
Return to “Drivetrain”
Login · Register
Login  •  Register
