Good day
I have recently experienced that the rear wheels feels much hotter when I stop at home
My only explanation for this, is that the brakes are actually binding, and not releasing all the time
I do hear at times, especially if changing from reverse to drive, that there is a sound (almost like air leaking out of a bottle), for about two seconds, when the vehicle starts moving. As yet I could not pin-point this to any particular wheel, but I expect it is the disk turning against the brake pads, before they release properly
Your advise will be greatly appreciated, if there is some sort of systematic procedure that I can follow, to maybe lubricate some parts, but which parts?
I do travel on dirt roads, but hardly any mud, and have never been stuck for that matter
Is it possible that the calipers could get dirty, and spraying them with "brake-cleaner" sprays might solve this? Or should I stay away from such sprays?
Could it maybe be the inner handbrake drum and parts that might become dirty?
Thank you to those that can assist
Andries
