Hi, im new here, so i dont know if im doing this in the right place,
I have a pajero gen 4 v83 GLS and it does not have the onboard display just the simple clock.
I would like to know if its possible to fit one, if the wiring is available, or what i need to get one to work.
The same question goes for steering wheel radio buttons, do you just need the buttons or what else do you need to upgrade?
Best regards
Texposto
Hi Texposto.
Not sure if I am helping, but your model sounds like the Africa Edition, which came out with less features.
My guess is there will not be any wiring in place, but removing the radio and clock facia should not be difficult so that you can check if extra wiring is there.
Also look under the " communications" thread to see there is anything posted that can help.
Best of luck
Best of luck
hi Mitsu Fan ,
Thanks for your reply,
I imported from japan to mozambique, but it does not have a lot of extras, ill attempt to look at yhe wiring, i did replace the radio at one point, but i dont recall what extra cabes it had there.
But thanks for help.
Best Regards,
Texposto
Best Regards,
Texposto
