ABS BOOSTER PUMP
I have a 2013 Pajero 3.2 DiD - for the second time in 4 years the ABS system failed.
The alarm is driving me nuts.
Previous time they replaced the brushes of the motor and problem solved.
Anyone experiencing the same and what did you do?
Re: ABS BOOSTER PUMP
Hi.
It seems you are nfortunate with the second failure. Normally the motor burns out and can be rewound, this may be the case with your's.
Only way out is to recon the motor again, or take the pain and fit a new motor.
Troll the Pajero group FB pages, there are 2. You will find suppliers who can help.
Good luck!
Thank you very much for you response and advice. I will follow suit.
