Replacement engine
If you have to replace your 2.8 (4m40) with another engine, what would it be?
:x No, the 3.2 is financially not viable. :x We have two Gen1's in Paarl using Nissan 2.7 motors and both the guys are very happy with it.
Johann Bredell
Re: Replacement engine
I know it's not the answer to your question but is the option of rebuilding the 4m40 not available to you?
4ePikanini wrote:I know it's not the answer to your question but is the option of rebuilding the 4m40 not available to you?
Been there, done that 45K ago. Looking at all my options
Johann Bredell
arnijr
The 3.2. More power, less consumption, fits the engine mounts and transmission.
arnijr wrote:The 3.2. More power, less consumption, fits the engine mounts and transmission.
If you go this route, make sure that you get the the full wiring loom with ecu, transponder and key barrel. It will make it a lot easier as I am yet to hear of stand alone management for the DiD - I suppose why tamper with something that's perfect ;)
boebie
jbeez wrote:If you have to replace your 2.8 (4m40) with another engine, what would it be?
Hi, currently doing a similar conversion to my (auto)blister fender. I'm fitting a 3l Nissan Maxima motor.Fitting Gotech PRO X management system on Tuesday. Do you have any advice / tips for me. Am i going to need a management system for the gearbox as well ?
Have a look at the spitronix management, they do one for gearboxes as well
Henk Bannink
I see imported motors have dropped in price. From +- R22k a year ago to under R15k now. Same cost as having the head replaced
Johann Bredell
Capricorn
Hi everyone,
Here is a new member from Botswana and I am desperately looking for an address where I can find an affordable 4M40 engine.
Local second hand engines are so expensive that I'm better of bringing the body to a car breaker.
I've found one company in Jo'burg that has it for R 13.000. Is this the going rate in South Africa?
Thanks, best regards,
Erik
tonton
Eric,
Welcome. Sorry, it seems your post was missed.
R13 000 for an engine?
Sounds too good to be true. You may want to check it out.
Let's see what the guys who have "been there" w.r.t. replacing engines have to say...
