Wit Wolf
1999 3.5 Pajero ry nie glad nie
Ek ry gewoontlik so 120km/h maar indien ek 'n ander voertuig verby steek en ek trap die petrol dan gee die pajero eers so drie rukke en dan tel hy eers spoed op. Ek het opgemerk dat hy soms dit in laer gears ook doen, byvoorbeeld by 'n stop straat weg trek. As ek die motor druk oor 4000 rpm raak hy vinnig warm en ook spring die rev counter naald rond. Daar is ook reek na exhaust gas as ek gery het en ek skakel die motor af..
tonton
Re: 1999 3.5 Pajero ry nie glad nie
Wit Wolf wrote:Ek ry gewoontlik so 120km/h maar indien ek 'n ander voertuig verby steek en ek trap die petrol dan gee die pajero eers so drie rukke en dan tel hy eers spoed op. Ek het opgemerk dat hy soms dit in laer gears ook doen, byvoorbeeld by 'n stop straat weg trek. As ek die motor druk oor 4000 rpm raak hy vinnig warm en ook spring die rev counter naald rond. Daar is ook reek na exhaust gas as ek gery het en ek skakel die motor af..
Wit Wolf,
I reply in English for the benefit of our members abroad.
Firstly: Do you keep your car serviced? Your "flat spot" problem seems to point to incorrect timing.
Secondly: you may have a dead plug? If you have platinum tip plugs, you tend to forget about them, and when they fail, they do it proporly.
Thirdly: Overheating is critical. You have to check your oil level, coolant level. Check for water in oil (milky), and have your thermostat checked. Overheating will kill your motor - do not wait, fix it now.
Forthly: the smell of exhaust gas could mean many things - if it smells like unburnt fuel, it could be the plug(s) and timing. If it smells like burnt oil, your rings may be on the way out or valve stem seals may be brittle and need replacing.
QUESTIONS:
1. How many km on the engine?
2. How much oil does she use?
3. Does she use coolant (do you have to fill it up from time to time?)
Maybe you will get more help if you reply to these questions, as they will indicate to some possible reasons...
