Wilddog
3.2 DID cambelt/camchain? Maintenance
Hi Guys,
Can anyone tell me if the 3.2 DID has a chain or belt? Is there any specific maintenance that should be performed? I seem to remember reading something about the tensioner device somewhere. any advice , much appriciated.
Thanks Wilddog.
tonton
Re: 3.2 DID cambelt/camchain? Maintenance
It has a chain. The chain does not need replacing. You have to check (and replace if dicey) the guides, however.
Here is a site with Mistubishi specs: http://www.um.co.za/specifications/mitsubishi.aspx
Wilddog
Hi Anton,
Thank you for the response. Is it a big job to check the guides?
Wilddog
tonton
Wilddog wrote:Hi Anton,
Wilddog
Wilddog,
I haven't done it myself, (too many thumbs on each hand), but I understand it is relatively easy.
Hopefully the technical fundi's will explain how it is done.
Also do a search on the forum - you'll be amazed by the volume of info already here. You can follow this one: https://www.pajeroclub.co.za/forum/sear ... d%5B%5D=24
Wilddog
Thanks Anton,
I found some valuble info on the links you suggested. I also found this link with further info.
https://www.pajeroclub.co.za/forum/view ... uide#p5744
shot for the help.
Wild dog.
