Re: Ignition timing
I doubt that you will be able to set up the timing accurately without the bottom cover.
I would in an emergency advance until it pings and then retard a marked point on the crank pulley (Harmonic Balancer) by 5mm which roughly translates to 2 degrees.
AFAIK you will have to undo the crank bolt to get that cover on/replaced - make sure you replace the crank bolt with the updated one
http://autosa.webs.com/apps/forums/topi ... bolt-issue
Frankm
Re: Ignition timing
Thanks, i will try and let you know how things went.
Frank M
Re: Ignition timing
Frankm wrote:Thanks, i will try and let you know how things went.
Frank M
Don't play if you are unsure. Pinging can cause a headgasket to fail pretty quickly or damage the main bearings or gudgeon pins.
Cobvs
Re: Ignition timing
4ePikanini wrote:I doubt that you will be able to set up the timing accurately without the bottom cover.
Thanks for that info. Didn't know about new bolts. Hopefully the agents will have them in stock.
