Re: 2004 gen 3 3.2 did auto start problems
if there is a puff of smoke it may indicate a lack of compression or bad glow plugs (bad battery perhaps)
if there isn't a puff of smoke it means there was no diesel introduced on the unsuccessful starts - which points to the diesel feed solenoid valve or diesel pickup pump in tank (if it has one) - also electrical.
zoobie
thank you sir
I will check all of the items that you suggested and report back.
kind regards.
