Re: EGT probe position
Mine is sitting much more to the front :?: almost on the outport of the first cylinder if i'm not mistaken
Will take a pic and post it tonight.
__________________
This is where mine is. its right on the first outlet.
Is that good or bad for the EGT reading?
EGT probe
EGT probe
__________________
JohanV wrote:This is where mine is. its right on the first outlet.
It seems to me that No 1 cylinder is the one most likely to fail (from what I read on numerous forums), so it is probably a good spot.
Now just add the three others! ;)
One obviously cannot drill right through the manifold without removing it, as it will be impossible to stop shavings from the drill bit and tap to go inside the manifold. If this happens you will have a very unhappy turbo. So is welding it on the better way?
Willie from Jo'burg
macjohnw
Bigwill wrote:One obviously cannot drill right through the manifold without removing it, as it will be impossible to stop shavings from the drill bit and tap to go inside the manifold. If this happens you will have a very unhappy turbo. So is welding it on the better way?
I would just undo the piece of pipe between the manifold and turbo (if easy to get in there), drill and thereafter give the engine a very short and quick turn to blow the rubbish out. Any bad points about this?
Transkeicowboy
Thanks everyone. Very helpful.
I bought the mgl setup last week. The gauge, probe and 1m extension wire cost about R 1 400 and cost for delivery to EL was R150.
