nicomar wrote:Engineering of heads at Antonios Paarl(skim, reseat valves, replace valve stem seals and lifters ets): R1428.28 for both
Parts: Water pump R695.11
Thermostat R102.32
Timing belt R825.11
Lifters R1490.57
Head gasket set R700.00
Crankshaft oil seal R45.00
All water and radiator hoses R700.00
etc. R500
Labour R1700.00
Thanks for sharing this info;
I recently had my timing belt replaced with waterpump, thermostat, all water and radiator hoses, thus from your list if I have the rest done, then I am in for;
Engineering of heads at Antonios Paarl(skim, reseat valves, replace valve stem seals and lifters ets): for both Engineering R1,428.28
Lifters R1,490.57
Labour R1,700.00 or should be part thereof
All in all, it should be around R5,500
Mitsubishi P/Eiland said they will charge 10 hours abour at R550/hour, Damn...
PLUS Engineering PLUS Parts
Nico - Please keep me informed of your progress
Thanks Boet!
Aslam
