Page 2 of 2
Re: 2 Stroke oil-professional test proves lubricity improvem
Posted: Wed Sep 21, 2011 2:45 am
by HBannink
Gemaskerde Tuinvurk wrote:I see you all use it on high-mileage engines.
What are the chances of me observing an impact at around 70 000km on the clock?
You will see an improvement but the biggest benefit will be seen at 300k, that is when the engine without it is shot and yours is only just run in :twisted:
This tip is as old as motoring and has benefited every "new technology" engine since when. I am sure if they had used it in the moon buggy it would have worked as well :twisted:
Posted: Wed Sep 21, 2011 7:12 am
by macjohnw
What is the ratio of 2SO to be added to the diesel?
Posted: Wed Sep 21, 2011 7:22 am
macjohnw wrote:What is the ratio of 2SO to be added to the diesel?
1 part 2SO to 200 parts fuel.
Posted: Wed Sep 21, 2011 7:29 am
by macjohnw
So on a 90L tank that equals 450ml? I read you guys refer to adding 200ml per tank.
Posted: Wed Sep 21, 2011 8:17 am
macjohnw wrote:So on a 90L tank that equals 450ml? I read you guys refer to adding 200ml per tank.
I usually just add a 200ml bottle or 250ml per full tank.
The ratio should be rather 200:1 or 250:1. If you put more 2SO you might get excess build up and smoke.
