Here is the link I was referring to, quite abit of info to read through though:
https://www.4x4community.co.za/forum/sh ... ero+monroe
I have been reviewing the Pajero springs and as per Dobinsons which appear to be highly rated by the Aussies, the springs do not appear to be tapered or progressive, and the guys from van Zyls share the same view.
Here is a link to Dobinsons catalogue:
http://www.dobinsonsprings.com/docs/cat ... alogue.pdf
Can someone confirm this please, if this is indeed correct.
David
David
wow, wish I found this thread earlier... a lot of questions answered!Davidvan wrote:Here is the link I was referring to, quite abit of info to read through though:
https://www.4x4community.co.za/forum/sho ... ero+monroe
Sent from a Desire HD with Forum Runner
Gemaskerde T,
What questions have been answered, there is so much detail on this post.
I saw the post around the EFS coils being hard, is this a result of a progressive coil, or was that a linear coil?
Please can you provide your review from your perspective.
Thx
David
Thx
David
Its quite a read, and a lot of it too technical for me. I read it over a few days, so I hope I get the most important bits:
Maybe Gerrit can help out, since he is one of the original authors...
- A good way to lift the car is through using spacers - but not many make these spacers for the pajero (if any)
- Spacers will however mean that you will need new shocks, since the spacers cause the shocks to extend beyond the range they were designed for
- There are not many shocks that extend further than the standard shocks, and those that do are difficult to find in SA
- The opinion seems to be OM > IM, especially on road (read the last page of the thread - Cats' experience), however IM seem to be much better value for money
Karl,
Thanks for your feedback, I am changing my possibilities here to consider a spacer kit, I am happy with the curent ride and don't want it to be hard at all. I have read on an aussie forum that the front coil spacers for the 80 Series fits perfectly for the Pajero rear coils without any modifications and this is around 70 Aussie dollars for a pair, excluding shipment and duties, and then just the front, will see what can be used there, it appears some shocks come with an adjustment already which can raise the front, I am just looking for a small lift (at least 20mm, mx 40mm) both front and back and have to replace shocks as I have a leaking shock up front.
I am busy with a excel sheet with 12 options, will publish once I have all the details and all the research complete. So far considering KYB (OE as I understand) and spacers with air helpers in the rear for overlanding.
David
David
That sounds interesting, what difference can the adjustment make to be safe, can it go to 40mm up front safely - end raise that is
Has anybody installed the Gabriel HDP shocks on a Gen3 yet?
I found on an aussie post that the Crusuer 80 series front spacers fit on the Pajero rear, see here which seem like they would be easier to source and not expensive which could make the whole issue alot easier and cheaper:
http://www2.pajeroclub.com.au/forum/sho ... php?t=7423
David
David
Here is an example of the Landcruiser 80 Series spacers (which as per a previous aussie post the front spacer can be used on the rear of the Paj Gen3), what are the thoughts on this? It is only USD20 for such a spacer, excluding shipping and import, but it is 30mm, what will the resultant lift be?
http://man-a-fre.com/pa/80seriescoilspringspacers.htm
David
David
