NickDavel
Re: High pitched squeal/whine from engine 4m40D
Brianrapson wrote:Hi Guys, I also had a high pitched squeal coming from the front of the engine, we thought it might be the V belt tensioner our mechanic confirmed it was not this and after tightening the belts VERY tight the noise reduced for a while the returned and got worse the next option was to take it to an aircon specialist who tested everything and declared nothing wrong with the aircon compressor. We then took it to a different mechanic recommended who discovered that the front crank shaft pulley was rubbing against the timing chain cover. The pulley has a rubber insert in it as a damper this had become detached and caused the pulley to rub against the cover. We got a second hand pulley from PartsHunt who were very helpful. After fitting the pulley no more noise and I have fallen in love with my Pajero again. I hope that this will be a useful experience to other owners when trying to identify mysterious squealing noises at the front of the engine.
I have exactly the same issue and Mitsubishi SA cannot supply the part. Order from Japan in 21 days if all goes well. I am stuck in Port Alfred in the Eastern Cape. Any info on PartsHunt or where else I can get the part from please? Will send a courier asap. Crank pulley Mitsu part number ME204075. Pajero 2003 3.2 LWB
